Cylinder compression specification for Bolt
Old Oct 16, 2002 | 04:30 PM
MotorCityBolt's Avatar
What is the cylinder compression spec for the Lightning motor. Not the compression ratio; but the compression of the cylinder. TIA
Old Oct 16, 2002 | 08:15 PM
LIGHTNINROD's Avatar
I d/k but this will TTT.
Dan
Old Oct 16, 2002 | 08:19 PM
Odin's Wrath's Avatar
8.4:1
Old Oct 16, 2002 | 08:37 PM
Crazyone's Avatar
Originally posted by Odin's Wrath
8.4:1
"What is the cylinder compression spec for the Lightning motor. Not the compression ratio; but the compression of the cylinder. TIA"
Well every truck will be differant, and typically i just do them all and they should all be withing 5-10% of each other. DUnno what fords spec is, but after hearing that a quart of oil ever 900 miles is 'spec' for oil usage i wouldn't trust their values.
Brandon
Old Oct 16, 2002 | 08:40 PM
Duh.......I guess I wasn't paying attention.
Old Oct 16, 2002 | 08:44 PM
Right, so, the thing to do os get all the values; and, as long as they all are within a certain %, that's will kind of tell you what you have. Thanks
