bellteck lowering kits????
Old Oct 16, 2002 | 02:34 PM
svtmike24's Avatar
on stylinconcepts they have the belltech lowering kit. they have the 3 in the front and 2 in the back. but it says on lightnings it will be a 2/2 drop. has anyone done this drop or is there something else?
Old Oct 16, 2002 | 02:41 PM
The Orphaner's Avatar
Registered User
Question 3-2?
Thats where I bought my Belltech kit from. It was listed as a 3/4..but is a 2/3 on an L.
Old Oct 16, 2002 | 02:49 PM
brap's Avatar
I have the 1/2 drop, I like it. But Orhpaner, that 3/4 drop on yours looks sweet ... think I may have to go with that next
Old Oct 16, 2002 | 03:53 PM
mecca's Avatar
I personally love the look of the Belltech 3/4 kits on our trucks... Tampa has it on his truck, which I saw in person and it looked killer!
-Mike
Old Oct 16, 2002 | 04:05 PM
Zman's Avatar
question for you all with the Belltech 3/4 or any knowledge of the system....have you heard of any major bottoming out in the rear? If so what was the fix?
-z
Old Oct 16, 2002 | 04:52 PM
93Cobra's Avatar
some have cut channels in the rear frame so that the rear doesn't bottom out. if i remember correctly only some had this problem. the only thing that i don't like about the bell tech kit is that it either levels out the truck, or makes it look as if the rear is sagging. if you have a hard bedcover on the back, then it really looks like it is sagging. when TAMPASVT, and RTKILLA (both use the 3/4c kit) took their bed covers off, the trucks looked 110% better in my opinion. not sure if there is a way to crank the back end up just a tad more to give it the much needed rake.
Old Oct 17, 2002 | 01:57 AM
1BADBLK01's Avatar
orphaner, what size rims are those? with that drop and those size diameter wheels it looks really nice. are they 20's?
Old Oct 17, 2002 | 02:18 AM
Registered User
Yes 1BadBlk01, they are 20's. I have never had the rear bottom out...but I did move the rear hanger to its lowest hole as to give it about a 1/2 inch raise in the rear. If you put it in the highest hole it will look like its sagging..LOL. Plus took a couple months of driving for the front to really settle all the way.
Old Oct 17, 2002 | 02:19 AM
Rayden's cloud's Avatar
for some reason when my buddy installed my 3/4 belltech kit he couldn't drop it the full length in the rear. He just set it a notch before the last on the shackles. Maybe thats why i'm not having any bottoming out problems.. Also mines have a raked look which looks great to me and a lot of people who compliment it.
Old Oct 17, 2002 | 08:18 AM
cabraco's Avatar
A good part of the bottoming out on the 3/4 kit results from hitting the pumpkin. If you look under the truck you will see a rail that runs from side to side on the bed of the truck that reinforces the bed of the truck. It sits directly over the rear of the pumpkin, and the top of the pumpkin will hit it. I used a cutoff tool to cut out approx 2" wide section along the lengh of the rail directly above the pumpkin to solve this problem. I left a small width of the rail in place. Helped out quite a bit. Added QA1 shocks. No bottoming out now
