Question for those with Wet Okoles
Old Oct 15, 2002 | 03:40 PM
baddgene's Avatar
I put mine on this weekend, and had a helluva time with the center peice. The lid cover went on easy enough, but the rest doesn't seem to act right. What's with the flaps around the cupholder hole? And it doesn't seem to want to lift up for the seat when it's on. I have to use the seat for my boy. So, right now, only the lid cover is on. How did the rest of you make out with this? It doesn't look too bad as it is because of the color, but I want it on. Thanks.
Gene
Old Oct 15, 2002 | 05:05 PM
captainoblivious's Avatar
My center one doesn't fit right either. For some reason it likes to move over to one side and cover the cup holder. But I just ignore it.
Old Oct 15, 2002 | 05:25 PM
Will Power's Avatar
Mine went on OK. I typically have the console down, but use it as a seat often and have not had a problem with the fit. Maybe Wet Okole could resend that piece if it doesn't fit right.
Old Oct 15, 2002 | 06:16 PM
Fast Gator's Avatar
I just chit-can my center piece
Old Oct 15, 2002 | 07:54 PM
CrazyFoo's Avatar
ya mine does not fit too great. and it is hard to close too.
Old Oct 16, 2002 | 03:47 AM
MORTIS's Avatar
Mines is the same way and I live in the state where they sell them. Actually they forced it on, the right side doesnt fit very well and the cup holder area constantly needs to be adjusted, oh yeah, you kinda gotta crunch it down to lock the console. On getting the seat up, you kinda gotta stick your hand on the bench under the foldup, push the foam down as you rotate that console up. I think the clearances are now too tight when you have the neoprene on both the bench seat and the foldup console. Just my .02
Old Oct 16, 2002 | 09:00 AM
dboat's Avatar
Mine was about like this too.. it was a B to get it on but it doesnt move around and I have to slam the cover for the arm rest to close.. but I still love the stuff...
Dana
Old Oct 16, 2002 | 10:40 AM
VINNIE's Avatar
My center piece lifts up with no problem.Also no problem with moving cup holders.I figured out the fix.Of course the third seat thing is a little bit of a problem.HEHE
