Barometric pressure sensor
Old Oct 14, 2002 | 03:35 PM
easterisland's Avatar
Is this the sensor? Does position matter when mounting?
Old Oct 16, 2002 | 01:52 AM
whtlight01's Avatar
No it doesn't I have relocated mine and have made a new bracket for it. I bolted it down with the bolt that is next to the rear bolt on the driver side fuel rail.
Old Oct 16, 2002 | 08:21 AM
Thanks, I am going to mount it vertical instead of horizontal.
Old Oct 16, 2002 | 10:49 AM
blackbolt's Avatar
Does any body know of where to get a portable barometer or device that tells weather conditions (temperature, humidity and the like)?
Steve
Old Oct 16, 2002 | 11:01 AM
jegs or summit
Old Oct 16, 2002 | 11:02 AM
NeedFourSpeed's Avatar
Blackbolt -
The most accurate way to measure temp and humidity is with a Sling Psychrometer. It gives you a wet bulb temp and a dry bulb temp which is used to calculate humidity. Much more reliable and accurate than all but the most expensive electronic gizmoes. The one I use is made by Bacharach and has a sliding scale that calculates the Humidity for you. You will have to go to a Science supply store, or, sometimes HVAC suppliers will have them.
I used it before every run when I was drag racing; just part of the log I kept.
Old Oct 16, 2002 | 01:27 PM
awhittle's Avatar
I saw the local karters using these. Provantage has them at $115
price quote at
http://www.provantage.com/scripts/go.dll/quote/72842
Palm pilot air density software at (free)
http://www.nwlink.com/~koryg/airdens...m/radpilot.zip
Hope this helps
Andy
