Lower pulley wabble ???
Old Oct 13, 2002 | 07:53 PM
Madhouse's Avatar
Anybody with an ASP cageless pulley - does your lower pulley wabble a bit while idling, then smooth out with a little throttle?
Thanks!
Old Oct 14, 2002 | 02:08 AM
echo5oscar's Avatar
I would really check to make sure it is seated properly. I had a s-10 w/a 350 and the crank pulley for the accesories did the same thing. A few hundred miles later the pulley broke on the expressway. Really messy, it went into the fan, which bent and cut into the radiator. Needless to say I had hard 2 mile ahead of me.
Old Oct 14, 2002 | 07:24 AM
02Thunder's Avatar
NO! My ASP pulley is rock solid! No vibes!
joe
Old Oct 14, 2002 | 10:54 AM
DR.D's Avatar
4# ASP lower. It doesn't wobble. I do tho'.
Old Oct 14, 2002 | 02:05 PM
Madhouse's Avatar
I pulled it back off and compared it to the 2#'er I had on there and noticed the center hole was much bigger - turns out it was for the '01-'02 model with a larger center hub.
If I had run it too much longer it probably would've sheared the bolts off and caused more trouble than I'd like to think about.
Old Oct 14, 2002 | 04:26 PM
SVT_KY's Avatar
Glad you found that out! !!! Coulda been a DIZ A$$ STER!!!
