Porting the mid? intake manifold?
Old Oct 10, 2002 | 06:38 PM
easterisland's Avatar
Question Porting the mid? intake manifold?
What are the eight intrusions for? Are they to direct airflow, mold reasons, strength? I was going to remove them if they aren't important. I don't think they are hollow, from the underside they don't appear to be.
Old Oct 10, 2002 | 07:57 PM
LIGHTNINROD's Avatar
I d/k but I bet they're there for some reason. I wouldn't grind them off/down unless someone else has done it before...............
Dan
Old Oct 10, 2002 | 08:48 PM
Dan
Umm, that is why I asked...
Old Oct 10, 2002 | 09:33 PM
captainoblivious's Avatar
Hey, you could be the first and let me know since thats the next thing on porting/polish list
Old Oct 10, 2002 | 09:40 PM
Bad as L's Avatar
Wink
The screws that hold the intercooler onto the midplate have got to have somewhere to go. If you grind those off, all that will happen is that it might expose the threads that come in from the bottom. Dale
Old Oct 10, 2002 | 09:58 PM
Thanks Dale.
Old Oct 10, 2002 | 09:59 PM
mecca's Avatar
I highly doubt that those could be restricting much airflow at all!
-Mike
Old Oct 10, 2002 | 10:06 PM
When you stick the blower case on top w/o the rotors it looks like the first two 'bumps' would cause some turbulance. I'm not an expert though. I would also think that the underside of the blower would cause alot of turbulance. i'm not sure how much it matters because all of the air is being forced through with so much pressure.??
Old Oct 10, 2002 | 10:10 PM
mecca's Avatar
Ah. Now that I think about how fast the air actually travels through there... Its possible those could restrict airflow a tad bit.
-Mike
Old Oct 11, 2002 | 09:29 AM
Silver-Bolt's Avatar
Rather than remove them they might benefit from a little reshaping and smoothing. Just a little clean up.
Old Oct 11, 2002 | 11:18 AM
I was just going to suggest that.
Put some JB weld before them (towards the front) and shape that to make a little ramp, or smoother transistion for the air to go over them.
Old Oct 11, 2002 | 01:07 PM
LOCOSVT's Avatar
Make sure you guys put 'JB weld' in your list of mods...
On second thought...maybe not...we don't want to start 'epoxy wars' like the 'washer wars', 'chip wars', and 'TB wars'.
Old Oct 11, 2002 | 08:25 PM
Okay, I did it. I hope it works out okay. If not I guess I can get the old 99/00 blower, intercooler, and intake from karkraft at the low price of $895.
Old Oct 11, 2002 | 08:41 PM
And get the intercooler leak mod??
I may just do that also. But since the blower is taking longer then expected I may have to wait until winter storage to do that. Not enough time to do everything before Fords @ Englishtown
