Took the truck in for a noise
My service advisor got a tech to listen to it. It makes a sort of squeaking rattling noise, really noticeable when the truck is idle in gear. They think that a pulley is causing the noise. He said that when it was loudest the idler arm was bouncing up and down. They looked at the lower pulley (JL 4#) and said that it looked like it wobbled a little. They said that I could bring it in for a warranty claim but I needed to put the stock pulley back on before they could make the claim. I just bought the truck used and don't have any of the stock parts. Anyone have one they are looking to get rid of? I am looking for the stock lower pulley with the cage.
My Email
My Email
Originally posted by Edward
There's nothing wrong with your truck. This sounds like the noise that has been refered to as cavitation.
-Edward
-Edward
Originally posted by Silver_2000_
I had a similar noise it was the idler pulley failing.. It Shouldnt be jumping under normal conditions...
Doug
! I had a similar noise it was the idler pulley failing.. It Shouldnt be jumping under normal conditions...
Doug
Thanks for the help guys!
They replaced the pulley on mine.. It was very clear because the sound was in unison with the jumping of the pulley.. From in the cab it sounded BAD.. Like a rod knock or something. There is no way that any mods would cause a idler to fail.. Unless they say that the lower pulley caused it to spin to fast. A 4# pulley caused the idler bearings to fail from over revving ?? LOL
Doug
Doug
Doug
! They replaced the pulley on mine.. It was very clear because the sound was in unison with the jumping of the pulley.. From in the cab it sounded BAD.. Like a rod knock or something. There is no way that any mods would cause a idler to fail.. Unless they say that the lower pulley caused it to spin to fast. A 4# pulley caused the idler bearings to fail from over revving ?? LOL
Doug
