How to????????????
Old Oct 8, 2002 | 03:43 PM
Boostin01L's Avatar
How to????????????
Can anyone tell me how to adjust the headlights up some?
Old Oct 8, 2002 | 03:45 PM
FastAsL's Avatar
i have the same problem. i believe that you remove the headlight and adjust the rubber stoppers....chris
Old Oct 8, 2002 | 03:49 PM
Boostin01L's Avatar
Not that much that is what you have to do if you get new ones I know I just want them up some and I can't remember how I did it on my stang.
Old Oct 8, 2002 | 03:56 PM
99 SVT Bolt's Avatar
You are correct sir! or I could be wrong!
Old Oct 8, 2002 | 03:58 PM
FireGuy's Avatar
Boostin01L ,
Behind the headlight are two silver looking screws sticking out, they have a very small hex head on them, (can't remember the size, like 4mm or so).
From my experience, the outer one, nearer the fender is the up and down adjuster and the inner one is the right left adjuster.
Use a cardboard box or piece of plywood standing in front of the light you are adjusting, turn it on and mark the top and bottom of the visible light pattern with a pencil or marker. Then begin adjusting slowly and check your marks. One inch higher on the box or wood at close range = a whole lot more light down the road.
If everyone is hitting you with brights, take it down a notch.
Good Luck.
Or just take it to a headlight adjustment station for the Auto Club, should be about $20 for an adjustment. (preferred)
Old Oct 8, 2002 | 04:19 PM
ema100c's Avatar
When I put the 2" drop shackles on the rear of my Lighting I adjusted my headlights to compensate for the change.
Don't take the headlights out! Just turn the adjustment studs to the desired height. I believe the end of the studs have a really small square head. I just used a small wrench or adjustable wrench to turn the studs.
Point your truck at a wall or your garage door so you can see how much you are adjusting.
Old Oct 8, 2002 | 04:57 PM
Boostin01L's Avatar
Thanks for the help don't worry no one is flashing at me it's just my dad's truck(f150)4x2 is so much higher his lows are like my brights.
Old Oct 10, 2002 | 05:38 PM
FastAsL's Avatar
i tried to find this "little silver screw" that you guys talked about on the back of the light, but couldnt find it.
chris
Old Oct 10, 2002 | 06:04 PM
FireGuy's Avatar
FastAsL,
Look straight down the first opening behind the headlight assembly, may not be silver, but there is an adjustment screw, looks like a piece of 1/4" all thread with an small hex head on it. Pep boys has an adjuster for Ford headlights, about 6 or 7 bucks.
