Bilstein Shock problem! HELP!
Old Oct 4, 2002 | 06:18 PM
Kuan's Avatar
Unhappy Bilstein Shock problem! HELP!
Ford told me that my front left shock is leaking because of my BellTech 3/4 lowering spring.
They said the warranty wont cover the repair because my spring is aftermarket
What should i do now? Change all 4 shocks?
Here are my options!
1. Doetsch Nine Position Adjustable Shocks
2. JDM/QA1 12 Point Adjustable Rear Shocks
3. Other shocks???
What do you guys suggest?
Thank you very much!!!
Old Oct 4, 2002 | 06:29 PM
cabraco's Avatar
Go with the QA 1, you won't regret it
Old Oct 4, 2002 | 07:13 PM
Kuan's Avatar
Question come on guys!
anyone???help???
Old Oct 4, 2002 | 07:16 PM
Twisted99's Avatar
I have no experience myself...But I did want to say how your truck is very sharp...Jeff
Old Oct 4, 2002 | 07:29 PM
thepawn's Avatar
I'd go with QA1's if you can swing it. I've got'm on all four, great shocks.
Daniel
Old Oct 4, 2002 | 07:47 PM
Spike Engineering's Avatar
Re: Bilstein Shock problem! HELP!
3. Other shocks???
Regarding item 2, if you go with the QA1's, I'd suggest putting on fronts and rears. Just make sure you get the correct QA1 shocks for your drop (different shaft length).
Old Oct 4, 2002 | 09:26 PM
slapshot's Avatar
If it were me, I'd throw the stock springs back on, go to a different dealer and let the warranty cover the shocks. That is BS saying the leak was caused by the belltechs.
Old Oct 4, 2002 | 11:32 PM
Kuan's Avatar
Thumbs up Thanx
Thanks for helping me!!
I might go for QA1 shocks but they are kinda expensive.
POWER IS NOTHING WITHOUT CONTROL
Old Oct 5, 2002 | 06:10 PM
Not necessarily. The stock bilstein stroke was designed for the stock suspension. If the shock absorber bottom out (On Compression), premature failure of the shock absorber could occur. The shock may not be bottoming out, but the dealer is not responsible to determine whether or not that is occuring.
Spike
Old Oct 6, 2002 | 01:24 AM
whoop72's Avatar
FYI I have had two of the Bilsteins go bad on my 01, one in the front and one in the rear. If you want to go ahead and change shocks, go ahead. But their failure may have nothing to do with your springs.
Old Oct 8, 2002 | 01:12 AM
Kuan's Avatar
Question QA1
I'll buy QA1 shocks from JDM. Im just wondering who should I talk to?
Do I have to change all 4 shocks? or just the front?
What do you guys have for your lowring suspension?
Thank You!
Old Oct 8, 2002 | 02:54 PM
Kuan's Avatar
Unhappy QA1
I just bought QA1 shocks front and rear from JDM. I told them about my situation but they didnt give me much suggestion, just told me to replace them.
I hope they'll be here soon!
Thanks guys for replies
Old Oct 8, 2002 | 03:14 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Drag race vs. Road Race
plain and simple
