Drop Shackle Questions
Old Sep 30, 2002 | 09:27 AM
jaymz's Avatar
Thinking of doing this, but even though I have searched and read numerous threads on this mod, I still have questions:
1. From what I can tell, you remove the existing stock shackles, which seem to give a 2" drop from stock 2WD F150. So, I'm assuming you order a 4" aftermarket shackle to achieve a 2" additional drop from stock Lightning???????
2. Do you specify a 2WD F150 reg cab to order shackles or do you specify "Lightning?"
3. Anyone have actual part numbers for Belltech or other aftermarket units?
Thanks!
Old Sep 30, 2002 | 09:29 AM
99svtlightning's Avatar
Just order a standard two inch drop shackle. It will drop your Lightning about two inches. Should be around $50 or so.
