Question on wiring up e-fan
Old Sep 28, 2002 | 10:08 AM
loosebolt's Avatar
Where did you tap into the AC so the fan kicks on with the compresssor? I tapped into the clutch, but now the fan turns on and off with the clutch, which doesn't seem right??
Old Sep 28, 2002 | 10:57 AM
tallimeca's Avatar
sorry,
but now you know why i paid the money for the JDM kit, looks awesome and works even better!!!
Old Sep 28, 2002 | 11:07 AM
Don's Bolt's Avatar
Mine is hooked into the power distribution box under the hood. I will take a picture and post it tonight.
Old Sep 28, 2002 | 11:17 AM
StruckBy99's Avatar
The tap shown for the A/C for the JDM fan kit is a ground tap, not power. Just be careful how you are installing the realy.
Jason
Old Sep 28, 2002 | 11:41 AM
loosebolt's Avatar
Switching a negative on the compressor should be easy. I'll go try switching my relay wires.
Old Sep 28, 2002 | 12:17 PM
loosebolt's Avatar
StruckBy99,
Where are you picking up the power for the relay then?
Old Sep 28, 2002 | 12:22 PM
StruckBy99's Avatar
You can use the ground tap shown in the JDM instructions. You just have to wire the relay like this................
Jason
Old Sep 28, 2002 | 12:40 PM
LTNBOLT's Avatar
Cool
The gray wire with the white stripe off of the AC clutch relay 204 (look in your owners manual for the location of the relay) . The wire is under the bottom of the fuse box which is under the hood on the drivers side.
Old Sep 28, 2002 | 02:58 PM
loosebolt's Avatar
Figured it all out....I feel like an a$$
I had everything hooked up correctly the first time, but when I was trying it, the ac clutch would kick on and off. Well, apparently it does that when the truck is cold. After I let the truck get to normal op temp, the clutch stayed on, and everything worked great! Little rework for a lesson learned
Fan works great too.
Old Sep 29, 2002 | 05:37 PM
jkbrand's Avatar
Loosebolt,
What kind of fan did you get? Where? How much?
Jeff
Old Sep 29, 2002 | 07:02 PM
loosebolt's Avatar
I got the permacool fan from Jegs...it was just over $100. Install was fairly easy. I modified the shroud so it would fit a little better and wired the fan to go on with the sensor, on with the AC and a manual toggle, too. The sensor is defective, but the fan seems to do a nice job so far.
