Trouble Code PO125??
Old Sep 27, 2002 | 10:10 AM
2020is's Avatar
Question Trouble Code PO125??
The scanner says "Insufficient coolant temperature for closed loop fuel trim" Has anyone else had this code after installing the hypertech 160 stat? I also notice on the scanner that my coolant temperature stays at 167-168* with the new stat. Thanks in advance for your replies.
Old Sep 27, 2002 | 10:30 AM
Don's Bolt's Avatar
Here is a list of ODD II codes, the list gives me the same code, but I can't tell you how to fix it. I run a 170 stat and don't have any problems.
http://www.obdiicsu.com/Docs/DTC/DTCData.html
