OBD2 Scanners & Questions....
Old Sep 22, 2002 | 09:19 PM
ICULOKN's Avatar
I know there have been a few new models out. I have some questions....
What brand have you guys found you like?
Where to buy one?
Any helpful Info?
Old Sep 22, 2002 | 10:15 PM
Chikenears's Avatar
Richard,
Did you get my email or PM from NLOC?... forgot which one I used
Tim
Old Sep 22, 2002 | 10:35 PM
SLVRLTNG's Avatar
I just got the Diablo Hellion OBDII scan tool.. It's pretty awesome, gives all kinds of info at real time and also gives trouble codes and can reset them......JR
Old Sep 22, 2002 | 10:39 PM
ICULOKN's Avatar
Tim,
Send me a email from here, I have not goten it.....
Old Sep 22, 2002 | 10:44 PM
2020is's Avatar
I have a EZ Link EXRay or something like that hooked up to my truck right now. Not to sure how to read a/f ratios though. Hard to capture WOT data when you are running WOT!!!
Old Sep 22, 2002 | 10:59 PM
Chikenears's Avatar
Done, check mail
Old Sep 23, 2002 | 06:29 AM
TheHylandr's Avatar
Richard,
I've used or seen just about every type of OBDII scanner and Autotap is by far the best that I've found.
The problem that I've seen with most scanners is they do not datalog, or if they do, they are too slow (readings every .5 seconds or so).
Old Sep 23, 2002 | 08:10 AM
99svtlightning's Avatar
I resell a companies software at a discounted rate. It is similar to Autotap and all of the other laptop based softare. You can check it out at http://www.obd-2.com and you can buy it w/ the discount at http://www.eldreth.net/shopping
Old Sep 23, 2002 | 09:10 AM
LightningTuner's Avatar
The best datalogging software I've found so far can be found at www.easesim.com . You want the personal use Ford OBDII package. It's very similar to Autotap, but I've found it to have better capability. You will need a laptop to use it. Many of the top Autologic tuners use the Ease software. Check it out .
Here's a link right to what you need, as it can be a bit confusing to find the first time you visit the site:
http://www.easesim.com/personal/personal_ford2.htm
Old Sep 23, 2002 | 10:49 AM
captainoblivious's Avatar
Originally posted by LightningTuner
The best datalogging software I've found so far can be found at www.easesim.com . You want the personal use Ford OBDII package. It's very similar to Autotap, but I've found it to have better capability...[/url]
Sal -thanks. It was a tossup between Ease and Autotap. Ease sounded better but a little overkill for personal use but I think I am going to go with Ease. Any other comparisons between the 2 that you can give?
Old Sep 23, 2002 | 03:29 PM
Sal or anyone else that has used Ease: I also heard from somewhere that the personal version of Ease only lets you scan a certain amount of vehicles? Is this true or not?
If it is true, do they mean you can only have X amount at a time, and if you want to scan more vehicle you have to delete other ones to make room. Or is it X amount only?
