Does a chip set a permanent unerasable code in the computer?
Old Sep 20, 2002 | 07:57 PM
Gen2 Lightning's Avatar
Question Does a chip set a permanent unerasable code in the computer?
I was told that it does. Is this true?
Old Sep 20, 2002 | 08:36 PM
speeder's Avatar
No, if you remove your chip and leave the battery disconected for about 30 minutes then hook everything back up, then drive your truck for a few miles with some key cycles in between, the dealer won`t know you ever had a chip without pulling your computer out and looking at it.
Larry.
Old Sep 20, 2002 | 10:06 PM
EvilL's Avatar
I know that the dealer can look at the board and tell the coating has been taken off, but can this really prove you had a chip in it? I mean isn't this a service port? Just seems like there could be other reasons for the coating being taken off. I guess you could always put it back on too.
Old Sep 20, 2002 | 10:09 PM
Flying Mofo's Avatar
Banned
Get a can of conformal coating. Its used on computer motherboards. Spray some in a cup. Use a foam paint brush ( home depot ) and lightly brush the contact pins blending into the pcb. They will never know you have a chip
Old Sep 20, 2002 | 10:11 PM
TYT-LYT's Avatar
I thought I heard someone say once that a dyno tuner might plug into that or something.?.? I have on clue though
Old Sep 21, 2002 | 05:06 AM
Thor01's Avatar
A dealer would have no (service) reason to remove the protective coating from the board. Our trucks have a sevice port under the dash for diagnostic tools to pull codes,erase or trouble shoot customer issues. As for disconnecting the battery to erase codes.
I have never seen codes erased from the PCM without having a scan tool. My truck has kept codes after disconnecting the battery.
Old Sep 22, 2002 | 11:03 AM
SVT_KY's Avatar
Thor, could you post a pic of that port?
I thought it was in the fuse box, but can't seem to find one.
TIA ...
Old Sep 22, 2002 | 11:11 AM
LightningTuner's Avatar
Cliff the OBDII port is under the dash, just to the right of the steering column. You can see it under there if you take a peek.
As Thor mentioned, the port on the PCM where the chip plugs into is not used for any reason in the service field. There is no reason that anyone would ever use that port, other than the manufacturer who builds the PCMs.
Interestingly, I know several people who've recently purchased new PCMs for their trucks, and they had NO coating on the port of the PCB. Kind of odd since the whole PCB gets coated at the same time.
Old Sep 22, 2002 | 01:44 PM
Spike Engineering's Avatar
Originally posted by LightningTuner
...Interestingly, I know several people who've recently purchased new PCMs for their trucks, and they had NO coating on the port of the PCB. Kind of odd since the whole PCB gets coated at the same time.
I wouldn't be surprised if the "new" PCMs are "used" PCMs with new code that have passed all the factory tests and checks. If the protective coating was removed, I doubt they'd put it back on.
