Intercooler fans installed (pic)
Old Sep 15, 2002 | 10:52 PM
VINNIE's Avatar
Installed the fans today.Real easy.I zipped tied them on and ran the wiring to the intercooler pump and switch that I use when I use my powercooler.So now they come on when the intercooler pump goes on and at the track when I flip the switch.
Old Sep 15, 2002 | 10:58 PM
DirtSlinger's Avatar
VERY nice!
I havent even bought my L yet and I had already planned on looking into this mod. Can't wait for your impressions
DS
Old Sep 15, 2002 | 10:59 PM
blown318's Avatar
Thumbs up
NICE!!! I need to do that mod!!
Old Sep 15, 2002 | 11:02 PM
Grey03's Avatar
I read somewhere that this mod is not a good idea because it blocks the intercooler radiator from much needed air going down the road or down the track. By the time you hit second gear, your trucks intercooler temp is back to normal no matter how long you cooled it off.
I would rather have the airflow across the intercooler radiator than obstructing it from doing its job.
Just my .02.
G
Old Sep 15, 2002 | 11:04 PM
VINNIE's Avatar
Just my .02.
G
When the fans are on they are PULLING air trough the intercooler.
Old Sep 15, 2002 | 11:12 PM
blown318's Avatar
yeah thats what i thought. I thought that was good to pull air thru??
Old Sep 15, 2002 | 11:14 PM
ICULOKN's Avatar
Just my .02.
G
All the fans do is help PULL the air threw , that is forced on the radiator by driving, These fans are on the backside, not the front....
Old Sep 15, 2002 | 11:16 PM
ICULOKN's Avatar
BTW....
Looks great Vinnie.... Im sure it cant do anything but help!!!!
Old Sep 15, 2002 | 11:18 PM
VINNIE's Avatar
Originally posted by ICULOKN
BTW....
Thanks, I am trying to get that powercooler back into the 11s were it is used to.HEHE
Old Sep 15, 2002 | 11:20 PM
StruckBy99's Avatar
Why did you put fans on if you have a powercooler??
The powercooler will drop temps way more than the fans will.
The colder temps going through the intercooler radiator, with ice in the powercooler, will be offset when the fans are trying to cool the radiator to ambient temps. Should have done one or the other, not both. Maybe you have plans to use them seperately??
Your install does look incredibly clean though. Good job.
Jason
mecca's Avatar
Sweet as always man. Good luck with the 11's.
-Mike
Old Sep 15, 2002 | 11:30 PM
VINNIE's Avatar
Jason
Actually what I was going for was effeciency.If the fans can help cool the fluid before the powercooler then the powercooler can cool faster.
I go through a lot of ice in the cooler and then it becomes warm water.If I can slow that process down it should help.
VINNIE
Old Sep 15, 2002 | 11:45 PM
StruckBy99's Avatar
Let me know if your theory works.
It might work better if you cool the intercooler radiator with the fans first, turn them off, then put ice in the powercooler and run the pump with the fans off. I think that pulling ambient air through the radiator the same time you have ice in the powercooler will just help melt the ice. Could be wrong, just let me know please.
I already have one 8" fan on the radiator and it helped TREMENDOUSLY!!! Cools to the touch in about 5 minutes. If you find a benefit with both, maybe I will still get a powercooler.
Jason
Old Sep 16, 2002 | 11:44 AM
ICULOKN's Avatar
Since I have had the Powercooler I will give you my thoughts....
The powercooler & IC pump work very well at cooling off the FLUID in the system. The cool fluid then cools the IC, IC radiator, and part of the motor if you let it run long enuff. The IC fans should help because the return water coming back for the IC will be warmer now while it trys to go through a hot radiator. SO in theory this is a precool of the water & radiator before it gets back to the powercooler.....
System flow is like this....
Radiator
Powercooler
Intercooler
Repeat Process....
Vinnie,
I told you ALOT of Ice will go through that thing QUICK!! LOL I think this mod should help slow down the ICE burn some. Worst case it will just help dispate heat easier, but thats a GOOD thing...
Old Sep 16, 2002 | 11:52 AM
VINNIE's Avatar
Radiator
Powercooler
Intercooler
Repeat Process....
Vinnie,
That was exactly my thought process.If it can help slow down the ice melting at all it should cool the motor faster.Like you said,it can't hurt to try new things.
VINNIE
