Fried tire splatter?
Old Sep 13, 2002 | 01:29 PM
frgetit's Avatar
Hey, did a little burnout a few days ago. Having trouble getting the hot tire splatter off my inside lower quarters. A little elbow grease gets some off, but others smear like tar or black bubble gum and some are SUPER hard. Any advice.
Old Sep 13, 2002 | 01:32 PM
Cheebmonkey's Avatar
Coke....
Or Pepsi...No I am not joking. The acid loosens it up enought to wipe off and it doesn't ruin paint.
Old Sep 13, 2002 | 01:37 PM
redlightspecial's Avatar
Turtle Wax Bug and Tar Remover worked for me.
Old Sep 13, 2002 | 01:40 PM
trashguy's Avatar
i thought i read somewhere about
spraying wd40 ?
Old Sep 13, 2002 | 01:48 PM
01Lightning's Avatar
Goo-Gone!
Old Sep 13, 2002 | 01:49 PM
Speedbump's Avatar
Post
WD40 works good. It takes some time to get loose though because it has to soak in. It also does a fine job at removing bugs. That's all I ever use, with a microfiber towel.
Old Sep 13, 2002 | 01:50 PM
dogleg's Avatar
They make something called Burn-Out gard. It works great, just put it on before you get the rubber on and it wipes right off.
Alvin
Old Sep 13, 2002 | 02:27 PM
NeedFourSpeed's Avatar
Raid your pantry and just spray on some PAM. Cheap and it works.
Old Sep 13, 2002 | 04:47 PM
99svtlightning's Avatar
They have this blue gel at Kmart that I use. It's some kind of bug and tar remover, works great. I also use WD40, but hate the oily mess.
Old Sep 13, 2002 | 04:52 PM
Fast Gator's Avatar
WD-40 works for me. You better get good at removing this mess or trade your truck
Old Sep 13, 2002 | 05:10 PM
SVT_KY's Avatar
Get M/T ET Streets .... Problem gone !!!
I used Goo gone once, but it dripped rubber
all over my driveway ... Truck is now clean,
but driveway is dirty...
Old Sep 13, 2002 | 05:28 PM
wydopnthrtl's Avatar
Go to a NAPA and ask for "prep solvent"
It's $25 a gallon but it takes everything off paint w/out hurting it. (wax, tar, ect....)
BTW: I just bought a gallon from the napa at novi and Grand River. Not all places stock it.
WOT
Old Sep 13, 2002 | 09:44 PM
Chikenears's Avatar
frgetit,
I had the same problem and once I scraped the rubber off with a bondo spreader and acetone, I put my first coat of Zaino on my truck. The rubber NEVER sticks now. Never!
Tim
Old Sep 13, 2002 | 10:29 PM
SLVRLTNG's Avatar
works for me too! I found a can in the garage that's probably 10 years old.....still works ....JR
Old Sep 13, 2002 | 10:38 PM
Rampage's Avatar
Registered User
Geddex Burnout Guard
Spray Geddex Burnout Guard on the body sections you used to scrub. Geddex dries clear and won't harm paint. It becomes a water-soluble layer of protection between hot splaters of tire rubber and the quarter panels of your truck. When you're ready, just rinse down the splattered area with water and wipe away the rubber.
Get it here...
http://www.blueovalperformance.com/a..._products.html
