Shackles and Springs
Old Sep 12, 2002 | 11:46 AM
IOPNER's Avatar
I am looking to do these myself. I think I am going with the Eibach/Belltech combination. Any tips or sugestion's?
As always your help is appreciated!!
Old Sep 12, 2002 | 11:53 AM
ICULOKN's Avatar
Jacks, Jackstands, & airtools.....
Old Sep 12, 2002 | 12:13 PM
jaymz's Avatar
I'm also contemplating 2" drop shackles for the rear.
Question: Do you specify ones for a Lightning or would they be the same for all Ford 2WD reg cab flareside?
Any part #s for BellTeck/Eibach would be appreciated.
Old Sep 12, 2002 | 12:15 PM
IOPNER's Avatar
I am looking at the ones on the Lightning Force or JDM Website. Not sure on P/N's
Old Sep 12, 2002 | 12:23 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
suggestion:
If you enjoy spirited driving/cornering, progressive rate springs (Eibachs) aren't the best IMHO. BTDT.
Ruslow, Hotchkis, Ground force.
Tips:
Perfect time to install anit-clunk washers and NAPA cam bolts.
Shackles are easy easy.
Bob
Old Sep 12, 2002 | 12:28 PM
01Lightning's Avatar
I just installed 2" shackles about a week ago, very easy and great results. I ordered mine from here for only $44 + shipping.
Old Sep 12, 2002 | 12:34 PM
IOPNER's Avatar
Do you have the P/N for just eh 2" rear shackles? I can't find them
Old Sep 12, 2002 | 12:36 PM
IOPNER, CLICK HERE
Old Sep 12, 2002 | 12:39 PM
IOPNER's Avatar
I still don't see just the 2" Shackles??
Old Sep 12, 2002 | 12:40 PM
You gotta scroll down a little... part #6400BLT...
If you still can't find them, you don't need to try to install them yourself anyway!
I know it does not say 2002, but I think they are the same.
Old Sep 12, 2002 | 12:52 PM
IOPNER's Avatar
I'm dumb....
I really can't see it. Here is what I see
Choose the Stylin' Stance that's right for you. Belltech manufactures a complete line of suspension components designed to build a truck to suit your personality and lifestyle. Vehicle drops are achieved through the use of matched components assembled in a complete system. Using Belltech suspension components for front drops from 1 to 5 inches and rear drops from 1 to 8 inches, you can custom build a sport truck to meet your specific objectives. To achieve a Mild, Raked, or Slammed look, please consult a Stylin' Concepts Sport Truck expert!
Tip: To sort the Parts listing, click on any underlined heading.
Item No. Description Application Brand QTY Price Add To Cart
4952BLT Front End Alignment Kit • 1997 - 2002 Ford F-Series(Light Duty)
Belltech $52.95 Each
5446BLT Front Sway Bar -- 1 3/8" Diameter • 1997 - 2002 Ford F-Series(Light Duty) - 2WD
Belltech $166.95 Each
5546BLT Rear Sway Bar -- 1" Diameter • 1997 - 2002 Ford F-Series(Light Duty) - 2WD
400BLT Complete Coil Spring Lowering Kit with Nitro Drop Shocks
Front: 3"
Rear: 4"
Kit Contains: Coil Springs, Hanger and Shackle Kit, Front and Rear Shocks • 1997 - 2002 Ford F-Series(Light Duty)
Belltech $379.95 Set
That's ALL
Old Sep 12, 2002 | 12:58 PM
soap's Avatar
When you click on the earlier link given "IOPNER, CLICK HERE" choose your vehicle ( 2001-Ford-F-series(Light Duty) ) and voila!!!!!!!!
It will be the first item available......
6400BLT 2" Rear Shackle Kit
*Must use Pinion Shim Kit 4975BLT (Extended Cab Chevy/GMC Only) *Fits 97-01 Ford F-150 Lighting for a 2" Rear Drop • 1997 - 2001 Ford F-Series(Light Duty)
Belltech $44.95 Pair
--Joe
Old Sep 12, 2002 | 01:01 PM
I had already selected my vehicle,,, maybe that's why it wasn't working for you like it was for me! Sorry!
Old Sep 12, 2002 | 01:02 PM
IOPNER's Avatar
--Joe
Tanks Guy's!!! I guess I am dumb
