Suspension problems...Help!
Old Sep 11, 2002 | 11:26 AM
wp4x4's Avatar
I have a 2000 lighting and I lowered it 1" in the front and 2" in the rear using the Ground Force lowering kit. Well I have had it aligned 2 times and I still have considerable tire wear on the inside of my tires. I have talked to a few more Lightning owners in my area and they are experiencing the same thing. Do any of you know if this can be corrected or is there a lowering kit that has spindals for the fron instead of just springs. By the way the 2 different places that did the alignment said it was impossible to set the camber to 0........Let me know if I am the only one......Thanks RICK
Old Sep 11, 2002 | 11:33 AM
NeedFourSpeed's Avatar
Did you install Cam Bolts on the front end? These will allow the additional movement necessary when aligning the front end.
Old Sep 11, 2002 | 11:36 AM
cobra97snake's Avatar
did you go to a place with a regular alignment machine...... i would try belle tire or someplace like that and get that $10,000 machine with the Laser alignment absoultly perfect everytime.
Old Sep 11, 2002 | 11:41 AM
LightningJMP's Avatar
You might also want to consider getting new lower control arm washers if you did not already, I have heard that shifting of the bolt can throw out an alignment.
Old Sep 11, 2002 | 01:37 PM
Spike Engineering's Avatar
The lower control arm star washers won't affect the alignment enough to be a problem. But, if the cam bolts/washers aren't installed, they won't be able to do the alignment to the stock specs.
