bumps in the lightning
Old Sep 11, 2002 | 10:35 AM
cobra97snake's Avatar
well i've put polk audio speakers in there. but i need better SOUND. anyone have that custom fit MTX thing that goes behind the seats? with the 2 10's??? did you get it with the amp supplied to buy a different one...... or what is your setup for bumps and how does it sound...... pics also appreciated.
Old Sep 11, 2002 | 10:42 AM
SVTRULZ's Avatar
How do you like the polks?Did they make a big improvement.
Old Sep 11, 2002 | 10:44 AM
01Lightning's Avatar
I had Polk 2-ways in my other truck, and they made a BIG difference! They sound superb, but I think this time I may go with Infinity or MBQuart just to try something different.
Old Sep 11, 2002 | 10:49 AM
SVTRULZ's Avatar
I just put in the small center sub.It sounds great for what it is.But I think there can be a better sound if we change the factory speakers.Is the 5x7 speakers smaller than stock.
Old Sep 11, 2002 | 10:58 AM
the stock measurement is 6x8 and 5x7 is actually the same size (i dont know how but it just is) well yeah the polk's sound great, but they cant do what they are intended for because i still have the factory head unit. but it does have good bass for 5x7 with really clear sound. but im looking at saving up some money and going with that MTX thing and a new headunit, either Pioneer or JVC
http://www.crutchfield.com/cgi-bin/S...20AG&display=L
click on the link to check it out.
Old Sep 11, 2002 | 11:28 AM
Madhouse's Avatar
If you get these Pioneers you'll have to dremel out the outer rim of the hole a little, because the basket doesn't quite snug in. It took me 30 or 40 minutes to grind out enough to snug them in. These are the TS-W1041DVC's. I've got a 720W 4-channel amp under the passenger's seat - two channels power the door speakers (Pioneer 2-way 6x8's) and the other two channels are bridged running parallel to the subs. The MTX box is pre-wired and only has one set of speaker connections on the back of it.
It hits real hard. Get the box unloaded ($159-$199) and put your own subs in it and get a good, high-power amp.
Old Sep 11, 2002 | 11:39 AM
thats the MTX box though i see, yeah i want that box cause it looks like it fits good and matches the interior. now any 10 will fit? im thinking either Polk (since i have polk speakers i just really like the sound.) and is there anywhere else i could put the amp? i really dont want to put it under a seat, will it fit behind that box or something? and how do you get just the box? i cant find it, all i find is you can only get it with the subs
Old Sep 11, 2002 | 12:58 PM
Madhouse's Avatar
Any 10 should fit, but like I said, if the basket is a little larger than the MTX subs that normally go in it you might have to dremel on the outer lip a bit.
I found no room under, behind, in front of, or on the sub box for the amp. You might be able to mount it on the back wall, depending on its size.
I got my box unloaded from a local stereo shop. When I went there they had the loaded box ($369, I think) and I had them take the MTX subs out and keep them, so I got it for $199.
Old Sep 11, 2002 | 01:58 PM
yeah i'll talk with the install guys that i usually goto about the amp mounting, i'll find a spot. thanks for the help, your set up looks nice, i see your a Pioneer man.
Old Sep 11, 2002 | 02:24 PM
Madhouse's Avatar
Pioneer
It's decent stuff...
Pioneer DEH-P9300 XM head unit
Pioneer TS-A6867 6x8's (4)
Pioneer GM-X564 amp (out of the truck right now)
Pioneer Premier TS-W1041DVC subs (2)
Old Sep 11, 2002 | 04:17 PM
Madhouse's Avatar
****, I forgot my flag...
Old Sep 11, 2002 | 05:58 PM
snoopy's Avatar
The JL Audio 250/1 amp just fits under the driver seat. It's a nice match for the Thunderform.
Old Sep 11, 2002 | 10:31 PM
svtmike24's Avatar
it looks good does it still have the same power as a custom box would
