2 lbs. pulleys (powersurge)
Old Sep 6, 2002 | 06:25 PM
still2slow's Avatar
does anyone know what the difference is on the pulley from the 99,00's -to the 01's . I have a powersurge 2lbs pulley and wanted to give it to a friend, and upgrade to a 4 lb'er, but on the website it says the pulleys are engine specific. I'm guessing that its the bolt pattern but don't know for sure..... I'm sure sal could answer this with his eye's closed and half his brain tied behind his back.
Old Sep 6, 2002 | 06:34 PM
LightningTuner's Avatar
The harmonic balancer is different between the 99-00s and the 01-02s. The hole in the center of the pulley that centers it on the balancer is a different diameter. You can't swap them out unless you have a 99/00 and machine it larger to fit the 01/02.
Old Sep 6, 2002 | 06:35 PM
still2slow's Avatar
sorry , just to be more specific I have an 01 L and his is a 99 L.
Old Sep 6, 2002 | 06:38 PM
You can't use an 01 on a 99, unless he gets an 01 balancer. The center hole is too big.
Old Sep 6, 2002 | 06:39 PM
still2slow's Avatar
thanks alot Sal , by that I see you couldn't go from 01 back to a 99 cause the holes aready to big. I apreciate the help.
( still 2 slow )
Old Sep 6, 2002 | 06:40 PM
still2slow's Avatar
I cant type fast enough you keep beating me to the punch!
thanks again
mike
