What should be my next "performance" mod?
Old Sep 4, 2002 | 03:27 PM
brasil's Avatar
Question What should be my next "performance" mod?
This is what I have in my 01
JDM single J39 program ( California 91 octane)
line mod valve
boost by pass
breather cap
cold air
line mod valve w/ 4x4 tranny pan
4# lower pul.
NGK tr6's
silver bullet (on order)
E-FAN w Cobra R water pump (on order)
What should be my next performace mod?
I don't want to increase the boost because it is my daily driver and I am limited to crappy 91 octane gas. In my mind the only thing that is left as far as performance mods is the single blade TB and long tubes with high flow cats, which are still not CARB approved in CA. What do you think? Any suggestions?
Old Sep 4, 2002 | 03:37 PM
run4bux's Avatar
If you dont want to do the exhaust, you might try a small shot of nitrous just to cool it off, or a converter, not extreme b/c it is a daily driver. Just my thoughts.
Old Sep 4, 2002 | 03:57 PM
brasil's Avatar
I have the silver bullet on order, which won't do much for power, but the long tubes and high flow cats are suppost to be illegal here in CA (no CARB or EO #'s yet).
Old Sep 4, 2002 | 05:01 PM
wydopnthrtl's Avatar
Thumbs up
Don't know if your into drag racing it at all?
You might consider some traction bars to help put the torque to use a little better? I've not done this on a lightning yet, but on other "cars" that produce a lot of low end torque, it can make a significant differance.
WOT
Old Sep 4, 2002 | 05:33 PM
mecca's Avatar
Ported/Polish upper plenum? Maybe a small shot of nitrous?
-Mike
Old Sep 4, 2002 | 05:58 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
next mod
Panhard bar =
Old Sep 4, 2002 | 08:55 PM
brasil's Avatar
Is teh polishing and porting of the upper plenum worth the $500 bones? I don't think i can safely run more than a 50 shot of NOS with my mods correct? Plus I would have to get a dual program chip in order to have one side burnt for when I am spraying right?
