Way off topic but I need help
I need some help. A friend of mine needs to put a device on the back of their car. (Kind of like a bike rack) This little device is going to weigh about 300lbs. The problem is that he cannot find a way to stiffen up the back end of his car. He has a 1998 Chrysler Concord but no one makes stiffer shocks or springs to handle the extra weight. The manufacture of the device says all you need is a class II trailer hitch for this to work. Does anyone know where I could point him to get this setup correctly and safely. We have tried the dealer, local truck/suspension shops, and a few places that sell trailer hitches.
Any suggestions would be greatly appreciated.
John
John
Is it for one of those electric wheelchair carriers? You can find the hitch here : http://www.reesehitch.com/89073_e74224.html and any local mechanic should be able to install it for around 50 bucks.
does it have rear leaf springs, or coil springs?? if leaf springs, you can get an "add-a-leaf" or "overload leaf spring add ons" from JC Whitney, if coil springs, get some inflatable air bags that you stuff inside the coils, to firm them up
I really dont think any suspension work is neccesary, its no different than having a couple people in the back seat basically the car will ride a little lower in the back but there should be plenty of suspension travel left.
There are special weight distributing hitches designed to distribute weight even between all 4 wheels but those are more for heavy loads like 700 pounds plus.
Its hard to realy help though not knowing exactly what the "device" is...
