How much gain from an 8#?
Old Sep 3, 2002 | 06:40 PM
run4bux's Avatar
Iwas wondering how much hp and tq from an 8# I just ordered mine today. Also what kind of time reduction will i see?
I have a cold air and borla catback.
Thanks Stan.
Old Sep 3, 2002 | 06:43 PM
Fast Gator's Avatar
I think traction would be your biggest problem
Old Sep 3, 2002 | 06:54 PM
95 Saleen S351's Avatar
It will go real fast....BUT
How much do you like your rods?
Old Sep 3, 2002 | 06:55 PM
wrightlightning's Avatar
Lightbulb
I hope you are getting a chip programmed for the extra boost...
Old Sep 3, 2002 | 06:56 PM
ib fast's Avatar
Around 2/10ths on my L over a 6#...actually i have seen 3/10ths + but the weather was cooler by 11 degrees and that particular track hooks a little better than the one were the L gained 2/10ths.
I gues what i want to know is how much gain does a 10# lower gain over an 8#?
Hey ib fast,
You have a built motor?
Old Sep 3, 2002 | 06:59 PM
ib fast's Avatar
Originally posted by wrightlightning
Hey ib fast,
You bet.
Old Sep 3, 2002 | 07:08 PM
run4bux's Avatar
How long can i expect the stocker to last?
Old Sep 3, 2002 | 07:39 PM
ib fast's Avatar
If you mean an 8# pulley on a stock engine....i have to go with the majority and say don't do it unless of course you are looking for an excuse to possibily build your motor in the near future.
Old Sep 3, 2002 | 07:45 PM
blown318's Avatar
I think new rods would be his biggest problem....
Old Sep 3, 2002 | 07:56 PM
RTKILLA's Avatar
you can get away with a 8lb lower on a stock bottom end. Think about all the guys running 6lb lower's and 2lb upper's opn stock bottom ends. Thats more then 8lb's of boost cause that 2lb upper is rated at 2lb's with the stock lower though, so its probably more like 10lbs'+. I know a couple guys with that combo on a stock bottom end and so far they haven't had trouble. I think its all the luck of the draw with these rods. Some are crap and some are pretty good, just depends on your batch that's in your motor.
I run a 4lb lower and 2lb upper with a 50 shot and I'm ok. thats allot more then a 8lb lower only.
Old Sep 3, 2002 | 09:01 PM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
No, anyone that knows you knows that you're not OK...
When are you going to stop running that "Ricer-shot"? j/k
Old Sep 3, 2002 | 09:06 PM
Fast Gator's Avatar
No traction would be because his tires would be coated in oil after the motor blows
Old Sep 3, 2002 | 09:07 PM
blown318's Avatar
LMAO!!!!
Old Sep 3, 2002 | 11:14 PM
BLOWN HARD's Avatar
I 2nd that! Be careful!
Dave
