Gauge Questions......
Old Sep 3, 2002 | 04:42 AM
ICULOKN's Avatar
For the Pillar Pod should I get a LOTEK or a RKKustom?? Is one better than the other??
The Lunar gauges are the best for matching the truck lights right???
On the A/F gauge, are you all taping into one of the o2's or do you put the new sending unit in??
Old Sep 3, 2002 | 06:00 AM
Nosdog2's Avatar
Cool
Check out this..
http://www.nloc.net/forum/showthread...threadid=25793
And I tapped into the wiring harness from the driver side just under the heat shield. BLACK WIRE.
Old Sep 3, 2002 | 08:40 AM
jarmstro's Avatar
Re: Gauge Questions......
Just keep in mind all you get with the A/F guage is nothing more than a light show. a real A/F guage is pretty much cost prohibited.
Black is correct by the way....
Old Sep 3, 2002 | 08:45 AM
Flying Mofo's Avatar
Banned
Ditch the worthless AF gauge for something more useful such as a Fuel Pressure gauge or Trans Temp. Unless you have a wide band o2 sensor hooked to that gauge, the readout is completely worthless.
