help with next mod???
I drive my L daily(22000 miles a year). Run at the strip about 10 times a month mostly 1/8th mile. Looking for the next bang for the buck. Considering LT's, bigger pulley, NOS. Any help would be greatly appreciated. Will probably build bottom end and trans at 50000 miles.
Assuming you have an 01 or newer I would add in the following order:
1) Long tube headers
2) High flow cats
3) torque convertor (because you go to the track a lot, be wasting a lot of gas as a daily driver)
4) Single blade TB
As a daily driver like mine, I wouldn't increase the boost. Maybe as you mentioned after your build your bottom end and tranny you can add more boost
2) High flow cats
4) Single blade TB
