Wix Fuel Filter
Wix Fuel Filter
Hey guys, I just did a search on fuel filters and found a post where someone installed a Wix #33595.
I went to the Autozone website, and it says the correct Wix number is 33296... does anyone know which one is correct?
I plan on changing mine today, but I bought the Purolator, and I saw a post saying that this one did not fit correctly. If not the Wix, what kind of filters to you guys recommend? I would get the Ford part, but the dearlership parts dept. is closed today.
Sammy: I use the K&N Gold filter(p/n 1011--I think). You'll be glad when you try and take it off as it has a 1" 'nut' on the bottom of the ffilter plus, it's rated higher than most others.
Dan
Dan
USE ONLY MOTORCRAFT FUEL FILTERS!
Well it is a fact, the Purolator fuel filter that I purchased will not fit in the mounting bracket. The length appears to be ok, but it is much bigger around than the factory filter. I also doublechecked the number, and I got the exact one that the book in the store said would fit!
Anyway, I am going to the dealership today to pick up a Motorcraft filter.
Dan: I have also been using the Motorcraft oil filters, but I think when I change my oil this weekend I will give the K&N a shot. I have just been hisitant to spend $10 on an oil filter!
