Help! Down on power.
Old Aug 30, 2002 | 11:07 PM
SVTDAVE's Avatar
did a search but couldnt find the right answers.....64 degrees outside...15,000 miles on the truck and my mods are PSP single chip, single blade T/B, 2# lower, JL ram air, Bazzani cat back, JDM electric fan and cobra water pump. My truck seens down on power and repeated WOT produced only 10psi when normal for me is around 13psi. Any suggestions? Truck also surges alittle bit on the highway cruising... Thanks for any help.
Old Aug 30, 2002 | 11:11 PM
brasil's Avatar
Could it be a clogged fuel filter or faulty plugs? How about the coil packs?
Old Aug 31, 2002 | 02:46 AM
captainoblivious's Avatar
Definately change the plugs and fuel filter. Clean the air filter.
Old Aug 31, 2002 | 04:44 PM
99 SVT Bolt's Avatar
Re: Help! Down on power.
TPS needs adjustment?
Old Aug 31, 2002 | 05:55 PM
SVTDAVE's Avatar
Andy, what is TPS?
Old Aug 31, 2002 | 06:15 PM
Fast Gator's Avatar
Throttle Position Sensor, that will cause surging at idle, don't know if it will cause problems like you describe
Old Sep 1, 2002 | 11:03 AM
Dave
oops my bad......forgot to include the link
https://www.f150online.com/forums/sh...threadid=66431
Old Sep 1, 2002 | 11:13 AM
ally69's Avatar
just guessing but with your boost being down im thinking cloged cats or restricted intake or something along those lines.
