Amp locations?
Old Aug 29, 2002 | 07:10 PM
Hamma's Avatar
Amp locations?
Well I broke down and purchased an AMP for the 4 new speakers im installing (didnt want to go w/a new head unit)
So anyway, curious as to where people have mounted their amps? I have to run 8 wires to and from the head unit to the amp. Plus the power cables, somewhere in the front of the truck would be ideal but i have a feeling that wont happen
thanx in advance
Old Aug 29, 2002 | 08:05 PM
Don's Bolt's Avatar
get 2 power link II's
http://www.linkmeup.com/
then go to PL2
They will allow you to go from speeker output to rca inputs to the amp.
Old Aug 29, 2002 | 08:06 PM
RTKILLA's Avatar
Mount the amp under the passenger seat. You can run all the wires under the carpet and you won't see anything.
Old Aug 29, 2002 | 08:07 PM
Silver-Bolt's Avatar
Under the center console. Of course this will only work with the seat conversion/Expy console.
Old Aug 29, 2002 | 08:08 PM
Cali L's Avatar
I put mine under the passenger seat. You just half to remove the jack. It depends on how big your amp is. Mine is a 5 channel so I couldn't put it any where else (I have a thunderform) without building a frame. All the pics I've seen posted have had framing done.
Old Aug 29, 2002 | 11:07 PM
snoopy's Avatar
I've replaced the head unit, but I still had to deal with the amp location issue.
I removed the stock jack bracket and put all the parts in a nylon zip bag. The bag is strapped to the bottom front of the passenger seat, with the stock threaded stud as the anchoring point.
I have a JL250/1 under the driver's seat, a JL 300/4 under the passenger seat, an Alpine CHA-S624 6CD changer and an Alpine XM tuner under the center section of the seat. Everything just fits with less than 1/2" clearance. An MTX Thunderform rounds out the rear. The cables to the headunit are all wrapped in a sheath and taped to the Dynamat Extreme under the carpet.
Old Aug 30, 2002 | 11:17 AM
bluetooth's Avatar
Arrow seats
I have amps under both seats. They fit & work fine. No problems,don't be worried about pulling seats to do it.
Old Aug 30, 2002 | 01:24 PM
Low_redL's Avatar
I put my 2 amps in the floorboard angled up right in front of the middle seat. I had a custom molding made around both ends of it to hide the wires and they were then ran back to the speakers. It's a pretty neat little setup.
Old Aug 30, 2002 | 04:35 PM
lisn4thawhistle's Avatar
i have seen amps mounted to the wall behind the seat under the rear sliding window, it looks good if your not trying to hide it
Old Aug 30, 2002 | 11:28 PM
djc cobra's Avatar
how odd snoopy
i have the same amps, and the 300x4 fits behind the pass seat WITH the jack in place
250x1 is behind the driver seat
Old Aug 31, 2002 | 12:23 AM
hdmlnium's Avatar
Wink
Mine are rate against the back wall, they are both mounted off of the custom box that hold 2 JL 10w3's. So there is nothing screwed to the back wall.
Bill
