S/C Oil
Old Aug 28, 2002 | 10:19 PM
Fordsrus's Avatar
Question S/C Oil
how often do you change the s/c oil? What kind dose it take.? I have about 5,000 miles on the L now.
Old Aug 28, 2002 | 10:21 PM
Don's Bolt's Avatar
relax
You don't have to change it for a long time
I am not sure what the recomended miles are, but at least 30,000 miles.
Old Aug 28, 2002 | 10:28 PM
mecca's Avatar
You should have gotten a service chart with your truck, or atleast I did. It tells me the recommended times to do certain things. Then again, you have the **** guys who do stuff 4 times in the period that Ford recommends it to be done once...
-Mike
Old Aug 28, 2002 | 10:42 PM
SpankDog's Avatar
Banned
My service guide thingee says nothing about S/C Oil though.............
Old Aug 29, 2002 | 05:11 PM
Fordsrus's Avatar
I too had looked in the service manual and nothing about s/c oil or how much and oil weight.
Old Aug 29, 2002 | 06:21 PM
GRY GHST's Avatar
Fordsrus,
Don't quote me but I believe the nose bearings are pretty much set for the life of the supercharger ~100,000 Miles if you don't change the pulleys. I owned a GM Supercharged 3800 and I only checked the level of the supercharger oil and never changed it. It lasted 110,000 before the nose bearings started to make some noise and the bower was replaced. I have also found that GM has the specially formulated supercharger oil a lot cheaper than Ford and both are from Eaton. As I understand it the oil is specially formulated to form a vapor at low temperatures for lubrication. Since the nose gear has no oil pump and the clearances are so tight only a oil vapor can do the lubrication. Caution, do not breathe in the supercharger oil, it's toxic.
Old Aug 29, 2002 | 06:37 PM
BlkBanshee's Avatar
Suspended Pending Email Reply
SVT states:
"Top off every 15,000 miles."
No changes necessary.
