Rattling, Ticking, Tapping noises with pulleys
Old Aug 26, 2002 | 09:44 PM
sc330's Avatar
After reading hundereds of Ideas from all the forums and only two responses to my last post I went through everything. Changed idler pulleys went through the whole exhaust for a leak you name it I did it.
But its fixed now!!!!
The lower pulley was a tad bit loose creating the noise at low RPMs, not enough lock tight I guess. I thought I would have a hard time getting it off because of how tight I put the sucker on but I am relieved no more annoying noises at idle.
Would recomend checking to make sure the lower pulleys are tight.
Old Aug 26, 2002 | 09:54 PM
mecca's Avatar
Hmmm... Im gonna be doing a full inspection. Ive got some weird noises from belt's, pulley's... im gonna go out and fix it all at once!
-Mike
Old Aug 26, 2002 | 10:23 PM
nostreetracing's Avatar
I had the same problem. Took it to the dealer and they replaced pullies and the entire S/C. Seems the SC was the biggest culprit in my case. Things runs quiet as can be now.
