4lbs Pulley And Spark Plugs
Old Aug 22, 2002 | 02:33 PM
struckby01's Avatar
Hey guys! Iam gone to install 4lbs pulley friday.My question is is it safe to do same drag racing with stock spark plugs in it.I have the chip and all the other goodies. Thank you.
Old Aug 22, 2002 | 02:35 PM
02Thunder's Avatar
Best thing to do is change the plugs. TR6s are fine. You might get a little detonation with the stock plugs on the top end.
good luck.
joe
Old Aug 22, 2002 | 02:42 PM
builtfordfast's Avatar
as 02Thunder said...
I run a 4# pulley and I am using ngk-tr6 plugs gapped at .042
Working very well for my combination.
You should change out the stock plugs.
F150online gallery
Have a great day eh ! ......... Dave
Old Aug 22, 2002 | 04:33 PM
frank2's Avatar
put denso's in mine ,running great
Old Aug 23, 2002 | 02:01 AM
struckby01's Avatar
ttt
Old Aug 23, 2002 | 11:00 AM
struckby01's Avatar
Question
anybody else
Old Aug 23, 2002 | 11:14 AM
TheHylandr's Avatar
You'll be fine with the stock plugs. I recommend changing them though, you'll be glad you did.
If you do, the NGKs are a good improvement, but if you want the ultimate, get the Denso plugs.
When I swapped to NGKs, I still had some mis-firing. On a recommendation from Richard (ICULOKN), I swapped to Densos. I now have no more mis-firing, my truck runs smoother and feels stronger.
Old Aug 23, 2002 | 11:17 AM
TheHylandr's Avatar
Let me clarify this...make sure your chip tuner knows you are using stock plugs, so they can ensure you have a mild program...then you should be fine.
They will most likely tell you to change them too.
Old Aug 23, 2002 | 04:46 PM
4D THNDR's Avatar
When I changed from a 2# to a 4# pulley I picked up a high RPM miss and slowed a 1/4 second in the 1/4 mile. Swapped to the Densos(20's) and the miss disappeared. Like it's been said, stock plugs are only good for stock engines.
Old Aug 23, 2002 | 04:56 PM
HIHOAG's Avatar
I have a 4lber with TR6s, runs fine.
Old Aug 24, 2002 | 04:47 PM
struckby01's Avatar
Wink
So guys what is the final answer.Can i drive with stock spark plugs and 4lbs pulley for few days or no!!!
Old Aug 24, 2002 | 05:14 PM
MRBBQMAN's Avatar
Post
sure you can, unless you have a lot of miles or a lot of "boost time" on your stockers, where they are worn or weak
Old Aug 24, 2002 | 06:54 PM
Red00Lght's Avatar
I drove 8 months on the stock plugs with my 4lber. (I was basically just lazy in getting the new plugs in). It ran fine and even after putting in the TR-6's I haven't noticed any difference...but it gave me piece of mind. So, as long as you aren't beating the hell out of the truck, stock plugs for a little while probably won't hurt it (don't quote me on this!)
Old Aug 25, 2002 | 03:15 AM
EXCITED's Avatar
4# er
4#er denso iridium IT 20's at .040 gap woeks great with my LFP chip.
