On topic, but an old topic, Brakes
Old Aug 21, 2002 | 10:10 AM
HIHOAG's Avatar
Question On topic, but an old topic, Brakes
Anything new out there?
I know about Brembos, fronts only for $3.5K
I know that there are some slotted and dimped rotors.
Best pads for street and some track?
I have the Raybestos ceramics and they blue the rotors
with any hard repeated stops from ~100 mph.
Thinking of a change, any suggestions?
Mark2
Old Aug 21, 2002 | 10:23 AM
Ruslow's Avatar
Some of the 'blueing' could be from what the pads make up is.I know that if it has a lot of carbon in it it will blue the rotors.If you change to a pad that does not have carbon in it I know that you will have less than ideal braking untill the carbon that is deposited on the rotor is worn off.stan
Old Aug 21, 2002 | 10:28 AM
whitelightnin''s Avatar
Lightbulb Stop Tech?
Please check Car & Driver, September issue. Tech Stuff:Shedding Light on Fading Brakes.
Old Aug 21, 2002 | 12:09 PM
HIHOAG's Avatar
Not sure how much carbon is in the ceramic formulation,
but I am pretty sure it is heat induced blueing as these pads seem to fade badly.
Mark2
Old Aug 21, 2002 | 01:09 PM
BlkBanshee's Avatar
Suspended Pending Email Reply
Hey, both Wilwood and Baer make kits for our trucks. I have no details on the Wilwood kit.
The Baer kit has 14" (unsure of the thickness, I think 1½") front rotors, and 6-piston calipers. This, too, is a front-only kit, and goes for about $2500.
However, Baer DOES offer a rear kit for our trucks.
Check it out on http://www.baer.com.
Old Aug 21, 2002 | 02:29 PM
HIHOAG's Avatar
I checked out the rear kit looks like OE equipment, no calipers, just a solid disc.
What do the F-350s or larger have on them for brakes?
I'm thinking like a SVT engineer now.
What can I steal from the standard parts bin?
Old Aug 21, 2002 | 06:31 PM
Ruslow's Avatar
NOTHING that will bolt on.After market is about it. I have made a few rear set ups from the 350 rears but its a pia! have to remake bracketsparking brake problems then you get into the ft to rear bais issues.Stan
Old Aug 21, 2002 | 09:25 PM
Spike Engineering's Avatar
... then you get into the ft to rear bais issues.Stan
...and these are important items regarding cost, safety and overall operation.
