Wont idle or run
Old Aug 21, 2002 | 09:35 AM
Crazyone's Avatar
Wont idle or run
Hey guys,
I have had a very intermitant problem with my 00, very occasionally it won't fire, when it does, it runs aweful, i.e. sputters, but barely maintains 500-600rpm. give it any gas and it stalls. I pulled 3 plugs and all looked good (well aside from a tad rich from where i've tried to get it running)
Chip is currently out and made no differance. Checked oil fine, and no water, checked water and no oil or bubbles.
What giveS?? CHecked EGR and looks fine.
Brandon
PS haven't run codes yet)
Old Aug 21, 2002 | 09:41 AM
LIGHTNINROD's Avatar
Hmmmmmmm.... How many miles on your fuel filter? That's suspect number 'one' for me.
Dan
Old Aug 21, 2002 | 09:48 AM
99svtlightning's Avatar
Check your MAF sensor and all the tubes going to your intake boot.
Old Aug 21, 2002 | 09:53 AM
Crazyone's Avatar
Angry
I just unplugged maf on a whim, idles up runs good, rev motor and it just acts like maf is unplugged. I guess this means its time to pull the mods and dealer trip -=(
Old Aug 21, 2002 | 10:32 AM
tallimeca's Avatar
before you go to the dealer
start you truck and run it. Go around an pull the wire off each coil pack 1 at a time (do this while the engine is cold so you don't burn yourself on the different components, also be carfull you don't get zapped too, might want to wear rubber gloves). When you pull each wire off, listen to the engine carefully for a change. If the engine responds to pulling the wire off, that means that coil pack is working. If you pull the wire and it sounds the same, chances are you have a bad coil pack, maybe more than 1. Happened to me last week. Dealer wants130 bucks for 1, got it at napa.....it's the same thing, for 50. Good luck. Let us know how you make out.
Old Aug 21, 2002 | 10:43 AM
easterisland's Avatar
Old Aug 21, 2002 | 11:21 AM
Cali L's Avatar
What you described happened to me awhile back. Fuel pump went out.
Old Aug 21, 2002 | 12:03 PM
bluetooth's Avatar
Arrow F.PUMP LINES
WHAT YOU DESCRIBE SOUNDS LIKE LINES OFF FUEL PUMP INSIDE YOUR GAS TANK. i HAVE A 99 L & IT DID THE SAME THING. IT WON'T MATTER TO PULL THE TANK,CAUSE IF THE LINES ARE ALL ON,THEN IT'S PROLLY THE PUMP. THROW ALL THE CHEAP CRIMP CLAMPS AWAY & USE RING-TYPE OR BETTER.HOPE THIS HELPS.
Old Aug 21, 2002 | 08:09 PM
Crazyone's Avatar
And the winner is no fuel pressure! Thanks for all the quick responses, pretty bad its under warranty an i am gonna pull the tank myself so the yahoos dont get my truck for 3-7 days to do a 2 hour job
Brandon
