Lots of greasy/oil on back right rim.
I clean the inside of the rim each time I wash the truck. For the past few months I've noticed that 3 of the rims only have dust on them with the exception of the right rear rim. This past time there was literally a greasy substance on there that was pretty hard to get off. What could be causing this? Is something leaking?
Had mine replaced about a month ago. They replaced my pads as well because there was so much grease caked on from the leak. If you wanna make sure it's the axle seal, crawl underneath and take a look at your wheel assembly. You'll most likely see fluid running down to the bottom.
No biggie. Just bring it in.
Dan
Dan
Soap dont scare the guy
"rear main seal" that would be alot of oil and a far distance to make it to the rear wheels
but like others said brakeline or axel seal
I think someone said something about the vent being clogged on there rear also check that could cause some pressure when it the rear gets hot coul dmake a seal go bad
slick
slick
This is a long shot
Does anybody have drawings or pictures of how the rear axel looks like (on the inside). Because I have to replace the seals, and I would like to know how it looks like before I get started.
