4# is on....questions though
Old Aug 14, 2002 | 07:43 PM
PFA's Avatar
PFA
Question 4# is on....questions though
I just put on the 4# pulley. First I want to thank Mike (FASTRNU) for getting me a GY belt! Thanks!!!
Now. How much more boost should I really see from the 4#? I see only about 3. I checked before and after the change. Is this right?
Second, I remember people talking of a noise after making a swap with pulleys, like a rattling noise, well....I have it. What is it and is it OK?
I think that is it. We'll see how I do at the track on Thurs.
Wayne
Old Aug 14, 2002 | 07:47 PM
soap's Avatar
Hey Wayne,
I had no noises at all on any of my pulley swaps. And as for the boost.....you will prolly not see 4# until fall (cooler temps). Last fall with my 4# lower on I was seeing like 13#
--Joe
Old Aug 14, 2002 | 08:27 PM
FASTRNU's Avatar
Your more than welcome Wayne. Good luck at the track!
Old Aug 14, 2002 | 08:29 PM
Litenin75's Avatar
The noise is cavitation in the supercharger. You can get your chip reburned to cut down on it, but it will have to be a softer program. The cavitation does not cause any problems to my knowledge.
Old Aug 14, 2002 | 08:30 PM
Chainsaw13's Avatar
From: Cuttin' Heads with Jack Butler at the CrossRoads!
Looks like I might have to come out to Milan after all. Weather's going to be a bit warm, so I may not run but I'd like to see what you pull Wayne.
Old Aug 14, 2002 | 08:36 PM
PFA's Avatar
PFA
Thanks for the comments. I hope the noise doesn't cause any problems.
If you come, I hope you show some support and RUN!!! Come on!
Old Aug 14, 2002 | 08:57 PM
Chainsaw13's Avatar
I have to take a look at my funds. I get paid once a month, so I have to be good at budgeting my money till next payday. I've probably already killed my budget for this month.
Bob
Old Aug 14, 2002 | 09:58 PM
Lightningquick's Avatar
Actually,the noise is probally the tensioner,you need to break off a little metal "nub"block with a hammer and pry bar
Old Aug 14, 2002 | 10:05 PM
frank2's Avatar
I changed my belt and went with a 67"( alittle tighter) had to break off the nub on tensioner but tensioner doesn't bounce any more,still get intermitant minor squeeking every now and then but nothing like I had,still might be tensioner but she is running fine
Old Aug 15, 2002 | 07:26 AM
PFA's Avatar
PFA
I changed the belt to a 67.5" from the 66". There shouldn't be any prob. from being too tight, I hope!
Old Aug 15, 2002 | 10:04 AM
BADBOLT2's Avatar
I just got the gatorback belt for my 4lb lower.I was told to get the 68"er.Will it work or will it be too loose??
I believe someone here was using it .I went this way so if I want to go with the 6lb it would still fit.
Thanks in advance for any help!
Old Aug 15, 2002 | 01:10 PM
BlackLight's Avatar
Lightbulb Air does not cavitate
If the S/C cavitates, you are racing a submarine...
