Self Made electric fan info
Old Aug 13, 2002 | 10:52 PM
whitetoast11's Avatar
Anyone out there bypass the tuners and build their own electric fan solution for their truck? I realize the tuners have good products as far as this is concerned, but it might be something fun to try on my own,,,, I dont get to use my engineering degree so much so I try to get as many projects as I can. Any input here??
`Toast
Old Aug 14, 2002 | 01:08 AM
captainoblivious's Avatar
One day I'm gonna try. But I do now some kits from other companies come with some wiring to hook up. Maybe not be as good as the tuners ones, which can do things like turn on when the truck is off. But that you could wire in yourself.
Old Aug 14, 2002 | 01:11 AM
yeah,, i've done a lot of reading about relays and such. Things in question would be I dont want to pull too many amps from using it, ( some spal fans need a whopping 24 amps for use) So I'd have to get specs on the stock setup first before I consider different directions to make it better. For example I'd have to know the cfm of stock.
Right now I'm basically looking to see whats out there, and why it is.
~Toast
Old Aug 14, 2002 | 01:34 AM
svt shawn's Avatar
toast
did you get my email
Old Aug 14, 2002 | 01:35 AM
Talleywacker's Avatar
Suspended For Violation of Vendor Rules
the fan i got uses 100 amps for 300milliseconds at startup and has a consistent 21amp pull.
Old Aug 14, 2002 | 06:55 AM
topsy's Avatar
I put a Lincoln Mark 8 fan on the Mustang I just sold. That fan can really move some air, it pulls a little over 30 Amps continuous.
Here's a website with a lot of good info, for Mustangs, but it pretty much will all apply to the L.
http://www.geocities.com/smithmonte/...rkVIII_Fan.htm
Old Aug 14, 2002 | 07:45 AM
soap's Avatar
Re: Self Made electric fan info
I haven't heard of anyone doing that
--Joe
