Install time on Metco pulley??
Got busy this weekend and did not get the pulley on as I thought. How long should this take to do for an avg. shadetree mech.(myself) and a better than avg. (my brother) to do? Also what size allen socket is needed to do this job?
Lower pulley?
If your talking about the Metco lower pulley, it took me about 20
minutes. I might add that I already had a cageless lower on my truck so the upgrade was easier. If you still have the factory lower I suggest you get the use of a lift. This being the case then you better plan for 1 1/2 to 2 hours.
Hope this helps
Marc
Hope this helps
Marc
I guess 2 hours is what I had guessed. I will probably not use a lift due to timing and scheduling. I want to try and get it during the week though.
Also, what size is the allen bolt?
