Water pump/fan question..
Old Aug 2, 2002 | 12:47 PM
JeffsLightning's Avatar
When pulling the stock fan off of the water pump I'm sure it is still possilbe to use the stock water pump without going to the Cobra R pump. My question is how does the fan attach to the pump? I see the four bolts but they look like they hold the pulley on. Does the fan somehow unscrew from the pump?
Old Aug 2, 2002 | 02:44 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
there is a big (as in pipe wrench big) nut that couples the fan clutch assembly to the stock water pump.
Looky here.
Bob
Old Aug 2, 2002 | 03:47 PM
soap's Avatar
Just to elaborate...........
The fan screws into that rusty looking thing in the picture Sir Speedy posted.
Beleive it is a 1 7/16" nut on the 01's (not sure 99-00).
--Joe
Old Aug 2, 2002 | 03:55 PM
wydopnthrtl's Avatar
http://briefcase.yahoo.com/bc/wydopn...c=bc%26.view=t
Just in case you cannot hold the pump still while taking it off?
This link will show a tool I made to do the job and NOT damage the pump.
WOT
Old Aug 2, 2002 | 04:52 PM
Is that fan nut righty tighty or lefty loosey You guys most likely saved me around a hundred bucks. I'll just use the stock pump with the new electric fan. I really don't think the $$$ per HP is good on a R waterpump
Old Aug 2, 2002 | 05:03 PM
When looking at the front of the motor, you will hold the pump still and turn the fan counter clock wise.
Before you go thru the trouble of making a tool, try to loosen it as is. I've seen some that will and some that won't.
BTW: I did'nt have BIG wrench so I just used my pipe wrench, got it snug and smacked it one time with a hammer. Then it turned off pretty easy.
WOT
Old Aug 2, 2002 | 05:05 PM
Old Aug 3, 2002 | 10:54 AM
Don's Bolt's Avatar
yep if your standing infront of the truck turn counter clockwise
