Dyno numbers for the ZR1 Killer
Old Aug 2, 2002 | 12:23 PM
Tiamat's Avatar
That's wild look'n!!
Old Aug 2, 2002 | 12:35 PM
BfB's Avatar
BfB
Banned For Rules Violations
Originally posted by Don's Bolt
I had a 2 lbs upper on the stock blower, the works has a similar sized upper, so the upper pullies are a wash. I also have a 6 lbs lower pulley
So basically you had the same rate of rpm spin on both comparisons then? Meaning, you tested both w/ 6# lower and both w/ 2# upper?
Also, does the blower's rear hit the firewall at all upon torque load? Could it?
Old Aug 2, 2002 | 01:09 PM
Dale-01L's Avatar
Lookin good Don.
My truck showed similar gains when I installed the Works blower.
Before: 392/471
After: 410/521
(Both tests with 91oct calif. pump gas)
Gained, on average, about 20-25hp throughout the ENTIRE rpm range and about 25-30 ft/lbs of torque throughout the ENTIRE rpm range.
This was with a 4lb lower and the Works upper, LT's, Single Blade TB, Filter & Chip.
-Dale
FYI- The Works upper is 2.80" diameter, which, if my memory serves me correctly, is the same size as the "2lb" uppers?
Old Aug 2, 2002 | 01:32 PM
mecca's Avatar
Very very nice. Looks like its a hot product right now.
-Mike
Old Aug 2, 2002 | 08:27 PM
Skip's Avatar
Works Blower
Question??? Can you change the passenger side plugs without removing the blower?
Old Aug 2, 2002 | 09:26 PM
soap's Avatar
Originally posted by Dale-01L
Before: 392/471
After: 410/521
-Dale
Nothing personal but that kinda sucks...........I made SAE 409/503 with only a 4# lower on a completely stock motor with just the regular bolt ons. A lot cheaper than $3500 for a new blower pushing 6#'s of boost over stock.
--Joe
Old Aug 2, 2002 | 10:35 PM
Skip's Avatar
horsepower
Dale's power figures are still good numbers. Remember in California , we only have 91 OCTANE gas. I am sure his numbers would have been higher if he could have put some timing in it, but that would require 100 octane race gas. His truck made that power on 91 octane with a street tune! Not saying that they are the highest numbers, just saying the blower did work! $3500 is a lot of money !! We will have to wait for the Kenne Bell blower and see which is the best way to go. By the way, the Works blower is a really nice piece. Workmanship looked excellent. Just can't figure out how you would change drivers side rear plugs without removing the blower. Skip
Old Aug 2, 2002 | 11:32 PM
Dale-01L's Avatar
Thanks skip
My truck is setup with 14degrees timing (max) and around 11.2-11.4 a/f ratio (on the dyno) At around 5,000 a bunch more fuel was added to keep the thing safe. (Around 10.8-11.0 a/f)
There is a lot more power left to be had, but I want a SAFE tune that I can drive around on the street with the horrible california gas and have no problems.
It should (hopefully) make about 430hp on the race side.
There is more to consider than peak horsepower as well. Area under the curve is whats important. I will post the dyno graph to look at (Left it at the dyno) but the graph is much higher and less "peaky" I guess you could call it. WE compared it to a truck that was making slightly more peak tq (with the stock blower) and, although it had more peak tq, my truck had a much taller graph, overall.
Also- I think I may have an issue with backpressure in my custom exhaust. I think the cats I have aren't "high flow" like they are supposed to be. Since I got the exhaust about 2 weeks ago, I have blown out the collector gaskets twice. I am going to cut the cats out of it and see if it improves any..
Hope that helps,
Dale
BTW- There is no way you will change the passenger side rear-most plug with the blower on there. The second one back *possibly* if you have a lot of patience.
Old Aug 3, 2002 | 01:58 PM
Blown93's Avatar
11's here you come.. Its so dam hot in the northeast no one can run to there potentials.. guess we just have to wait for the cooler temps.. Im doing some work on my 93 and waiting paitently for cooler temps...
Blown 93 Lightning
1.83
13.2
103.00
True Blue 2002
Stock excpt bed rug and tint...
1.98
13.44
102.00
Old Aug 3, 2002 | 02:38 PM
Fast Gator's Avatar
Hope that helps,
Dale
I thought that Calif had not only the worst gas BUT the most strict emission laws. so how can you "gut" the cats and still pass?
No flame, just curious......And you know curiousity killed the cat.Hahahahahahahahahahahahahahahahahahahahahaha
Old Aug 3, 2002 | 08:46 PM
LIGHTNINROD's Avatar
Dale: Get a hold of Sal and ask about the plug issue. He's had a Works s/c on for a few months now.
Dan
Old Aug 4, 2002 | 12:27 AM
Dale-01L's Avatar
Gator-
Im not worried about emissions We do have very strict laws about that, but I intend to just flange both sides of the cats, as well as the new straight pipe replacement so I can just bolt the old cats into place if I need 'em
FYI - I ran a 12.35 @ 110.5 today in horrible air and only the mods listed in my post above, with the addition of a set of 28" slicks & traction bars... I am very pleased with the works blower.
-Dale
Old Aug 4, 2002 | 03:07 AM
RTKILLA's Avatar
Don have you thought about just putting a KB blower on your truck instead?
Thats what I think I'm going to end up doing on mine.
