Pulley question for tuners........
Old Jul 24, 2002 | 08:00 PM
Odin's Wrath's Avatar
.......or number crunchers. Which makes more boost, the 4# lower pulley or the 2# lower pulley with a 280 size upper pulley combo? I don't think I've seen this question asked before now. I probably missed it.
I'm thinking that the combo makes more boost. How much more, if this is the case?
Roger
Old Jul 24, 2002 | 08:42 PM
BfB's Avatar
BfB
Banned For Rules Violations
Re: Pulley question for tuners........
The same w/in a 100 rpms it seems
Here:
Stock Lightning lower is 7.5" and upper is 3".
7.5 / 3 = 2.5 (pulley ratio) x 5000 (rpms) = 12500 rpms
I believe a 2# is going to be 8" approx., and the 4# lower is 8.5 (someone correct me if I'm wrong, please!). So:
8 / 2.8 = 2.8571 x 5000 = 14286
8.5 / 3 = 2.8333 x 5000 = 14167
It should be basically the same give or take a few. The way pulley manufacturers actually measure is different from each. I've seen ASP state 2.78, so then the differences is extremely slim.
Old Jul 24, 2002 | 09:07 PM
Silver-Bolt's Avatar
Stock upper is 2.93" and I think the 4lb lower is 8.75 (I may be wrong on the lower).
Old Jul 24, 2002 | 09:44 PM
HIGH ROLLER's Avatar
Cool
Stock Upper is 2.93 and a 2# Lower is 8.00 and a 4# is 8.50
2# Lower and Upper: 8 / 2.8 = 2.8571 x 5000(rpms)= 14286
4# Lower and stock 8.5/2.93 = 2.9010 x 5000(rpms)= 14505
Therefore the 4# Lower should make more boost and power than the other setup by a little bit! Also if you do this formula a 4# lower and upper will make a little more power than just a 5# Lower and stock upper.
Matt
