Nitrous Questions
Old Jul 24, 2002 | 10:23 AM
easterisland's Avatar
Question Nitrous Questions
What fuel upgrades do I need or should I have for a 150/200HP wet shot of nitrous? Fuel regulator, fuel rails, high volume pumps, etc?
Old Jul 24, 2002 | 12:39 PM
1BADBLK01's Avatar
nitrous
i hope your not running a stock shortblock with that much spray.
Old Jul 24, 2002 | 12:42 PM
red00Lightning's Avatar
Re: nitrous
If so, He won't be for long
Old Jul 24, 2002 | 12:44 PM
tommylightning's Avatar
Re: Nitrous Questions
Everything you have listed. You may also need to upgrade your supply lines.
It also depends on how much boost you will be running.
Old Jul 24, 2002 | 01:28 PM
Okay, maybe I should ask how much can I spray w/o going to new fuel lines, pumps, rails, regulator, injectors?
Tommy, what do you have as far as fuel system upgrades?
Old Jul 24, 2002 | 01:30 PM
Re: nitrous
I want to be the first to run a 200hp shot on a stock block with a 6lb lower.
Old Jul 24, 2002 | 01:31 PM
Re: Re: nitrous
It's a Ford. Of course It will take it. Probably a 250hp shot and 6lber before a rod or wrist pin breaks.
Old Jul 24, 2002 | 03:03 PM
Well at this point I have nothing done to my fuel system. I will be doing the fuel pumps ASAP. My current setup is an 8# pulley (aprox 16lbs of boost) and a 75 shot (Wet). I am running some Xyline mix (aprox 101 oct). At this time my program is a bit on the extreme side. I have a Diablo Delta (2 program) with a street/race nitrous and a race no nitrous. The timing on the street side is supposed to be 15 deg and is showing 19.5. The race side (took out a few plugs even with race fuel and no nitrous) Is suposed to run about 19 deg but a data logging showed timing of 27 deg and not even at the top of the gear. So I need to get some new programs before running my L again.
I also have an appointment to get my steering box looked at (leaking, should still be under warranty)
Old Jul 24, 2002 | 03:05 PM
Is it the power steering pump? I've seen a lot of those leak.
Old Jul 24, 2002 | 03:14 PM
I have not climbed under yet but it seemed to be coming from the equipment the steering rod is connected to (not sure what it is called) But I may be wrong.
