SAE vs. STD Dyno Comparison!
Old Jul 21, 2002 | 11:51 AM
BfB's Avatar
BfB
Banned For Rules Violations
Thumbs up SAE vs. STD Dyno Comparison!
To Everyone: ALWAYS have your #'s displayed in SAE. That is the ONLY true way we'll get accurate comparisons of these trucks.
Here's the reason why:
BfB's '01 COMPLETELY Stock using STD as the correction:
BfB's '01 COMPLETELY Stock using SAE as the correction:
Old Jul 21, 2002 | 11:16 PM
reality1's Avatar
Hey BFb,
What were your Cyl head temps?? How about air inlet Temps? Humidity?
TRUE Reading?
Old Jul 21, 2002 | 11:24 PM
BfB's Avatar
BfB
I have no idea what my cylinder head temps were, as we didn't measure anything else but the power. It was a HOT day, let's just put it that way
Here's an "Actual" power graph with conditions, though:
#'s on Actual were:
Max Power = 330.15 Max TORQUE = 398.26
As I said, it was a NASTY hot day and the humidity was awful (near 100%).
Old Jul 22, 2002 | 12:07 AM
Tim Skelton's Avatar
Re: SAE vs. STD Dyno Comparison!
Even if everyone begins using the appropriate correction factors (which would definitely be a good thing), results from two different dynos should not be compared. All dynos are different from model-to-model and brand-to-brand. Even two identical Dynojet models will produce different results, often being off by several percent. If one is just 3% over and the other is just 3% under, on a 350 HP engine, the error would be about 25 HP between the two. Camparing results from different brands of dynos can produce differences of 20%!
The only accurate way to use a chassis dyno is to do before-and-after comparisons on the same dyno.
