*phew* changed the brake pads...
finally got that over with.. replaced them with the ceramix pads from NAPA .
the inner pad on the front passenger side was gone... all the rest of the pads had 1/2 to 1/3 compound left..
went ahead and had both rotors on the front turned since the backside of one was chewed up a bit. good thing my friend's dad owns a tire shop.
i need some help with changing out the brake fluid.. i bought some valvoline high temp brake fluid. (the best i could find with a high "wet" boiling point)
http://www.valvoline.com/pages/produ...asp?Product=51
how do i go about changing the fluid? i sucked some out of the tank, but there is a small disc floating in there that is keeping me from getting all of it out..
anyone have any hints? thanks!
Congratts on your new brake pads
I just changed my pads for the 2nd time in the past month, I am getting real good at it.
You might want to look at these
http://www.speedbleeder.com/
I may try them next time I have to bleed mine.
I just paid someone $25 to do mine a while ago. They used a vacuum bleeding tank, took them 20-30 minutes
Just FYI, I had the NAPA cermix, they're a great pad and put off alot less dust the regulars, but they do not last as long. My stock pads went about ~19-20k miles, my Cermix went ~14k, and I havn't "changed my driving" much.
Daniel
Daniel
Re: *phew* changed the brake pads...
Spike
well, i would have made it to at least 40K miles on these pads if that one hadn't gone to brake pad heaven... so if the NAPA's make it to 30K, i'm in good shape...
spike, what do you think of the fluid i got? it should be a little better than the stock stuff, huh?
...spike, what do you think of the fluid i got? it should be a little better than the stock stuff, huh?
minimum dry boiling point: 502 deg.
minimum wet boiling point: 343 deg.
i also saw some DOT 5 brake fluid, but was told that it would eat the rubber up in the brake system.. is that true?
Fluid sounds pretty good... I just ordered Neo Superdot 601 fluid for my brakes...
"NEO "Super DOT 610" brake fluid is designed with a wet boiling point of 421°F and dry boiling point of 610°F. "
Daniel
Daniel
btt for spike..
didn't know if you had seen the info on the fluid.. any directions yet? thanks in advance.
brooks
btt for spike..
brooks
Will you be doing it alone, with a helper, with or without a pump?
cloetek hi ,
In the UK 5.1 is the best level of brake fluid ,highest boiling point and recomended for abs ,( for road use ) .
Has anyone sujested silicon brake fluid , dont have to change ! and it dont harm paint work .
As for bleeding as long as you use an air tight pipe from the nipple into a large jar and the end of pipe in the jar is covered with fluid you can pump the new fluid in starting at the R.R then L.R then R.F and last L.F. ? IT helps if your on your own .
Good luck from over the pond !
Phill
Phill
Spike: i will have a helper... no pump that i know of.
phill250sduk: i was told that unless the vehicle came with it stock, the silicon based fluid would eat up the rubber in the system...
i have a piece of hose that i will have running down to a jar with fluid in it, so no air can get back into the line.
LightningDammitt: they have a lifetime warranty for cracking.. not for normal use.. thats what the napa guy told me.
lol...
