air intake
Old Jul 17, 2002 | 05:06 PM
krnlightning's Avatar
air intake
As most of you know im new to the this board. I did a search about intake systems and i found something but it didnt really help me. maybe searching for the wrong thing. anyways I was wondering if i should get a cone from k&n or should i stay with the box and get a K&n box. When i got cai cold air intake for my maxima, i remember that just a popcharger would take in hot air so it was not as good as the cold Air Intake. So what do you guys think i should do. save my money and get like a airaid or one from jdm or should i just stick with stock box and k&n filter
thanks for reading
take care
Old Jul 17, 2002 | 07:59 PM
LIGHTNINROD's Avatar
Lots of guys go with the K&N flat filter and cut holes in the bottom of the box..or remove the bottom altogeather(see BfBs).
I prefer the PSP Fast Air(or fresh air ) kit. Two tubes bring cooler air to the filter which is somewhat protected from eng. heat by a metal box.
Dan
Old Jul 17, 2002 | 08:15 PM
BfB's Avatar
BfB
Banned For Rules Violations
Originally posted by LIGHTNINROD
Lots of guys go with the K&N flat filter and cut holes in the bottom of the box..or remove the bottom altogeather(see BfBs). [/B]
Thanks Dan for the plug!
krnlightning, see here:
http://lightningforums.com/forums/sh...hp?threadid=54
It works
P.s. The real credit must go to usahooters for this quick and easy trick!
Old Jul 17, 2002 | 09:16 PM
JeffsLightning's Avatar
It works
Didn't that setup loose HP vs the closed stock box?
Old Jul 17, 2002 | 11:30 PM
BfB's Avatar
BfB
No. Forget what you read that time.
Old Aug 13, 2002 | 07:02 PM
hay bfb is that set up ok for daily driving?
and how much do u think it helps?
Im not sure if i should do this or get an airaid
and also did u do this or do u have some other kit??
thanks
Old Aug 13, 2002 | 07:34 PM
2001SilverL's Avatar
I dont think K&N makes a Air Filter Kit for the L's, my best bet would be go with PSP or JDM's Air Filters, or Fast Air Kits
Old Aug 13, 2002 | 07:54 PM
they make one
but i was just wondering which is better
i dont have that much money thats y
thanks
Old Aug 13, 2002 | 08:31 PM
so what do u think of airaid
thanks
Old Aug 13, 2002 | 08:33 PM
The PSP entire kit is about 400 bucks as in fast air kit, but just the filter itself is about 179
Old Aug 13, 2002 | 08:41 PM
Take your time and save up for the PSP Fast Air kit. If you buy something else(cheaper) now you will be disappointed and may end up spending even more later.
Having said that, usahooter's mod will work(just not as good as the PSP kit[IMHO]--more 'cool' air with it) and is cost effective but you will hack up your stock air box whereas, with a kit you keep the box whole and 'new'.
Dan
Old Aug 14, 2002 | 02:30 AM
but u dont really hack up anything its it just drilling like 2 holes and u dont even have too but anyways what do u think about airaid and is it any good
thanks for the help
Old Aug 14, 2002 | 05:53 AM
Fast Gator's Avatar
put 20 a week away till you have enough to buy a cold air kit. That way you will get the best and you will not have wasted money buying something that you will replace later
