Need Help Fast.......
Old Jul 12, 2002 | 03:27 PM
blown318's Avatar
Just put driveshaft back in truck.....now where the driveshaft goes into the trans it is pouring out trans fluid.... is there sum type of gasket or sumthing i need??? any help greatly appreciated....
Old Jul 12, 2002 | 03:32 PM
ICULOKN's Avatar
Is it doing it with the driveshaft in or when It was out? The tranny lubricates the Yoke and seals up by the boot thats around it. Alittle fluid is normal, and if you started the truck with it out, you will get alot.... Drive it and see what you get....
Old Jul 12, 2002 | 05:35 PM
Fast Gator's Avatar
Maybe some grit on the spline thats keeping the seal from making proper contact?
Pull the driveshaft and wipe down the spline with a clean rag, Hope thats all it is. Good Luck
Old Jul 12, 2002 | 05:38 PM
Silver-Bolt's Avatar
You might have boogered up the tailshaft seal. Hopefully it is just dirty. Just like sex, never try and put it in dry. Make sure the shaft is lubed before you slip it in.
Old Jul 12, 2002 | 05:41 PM
LightningTuner's Avatar
The tailshaft seal is more of just a "dust cover" really for the splashing fluid from the tailshaft seal, the only fluid back there is what feeds the tailshaft bushing. It may be possible you could have either damaged or knocked the tailshaft bushing out of whack.
Old Jul 13, 2002 | 11:07 AM
blown318's Avatar
Thumbs up
Thanx guys, we got it taken care of!! Apreciate the help.... also got my caltracs on from SAL!!!! world of difference!!!!! Very nice product!!!!
