May be going to E-town tonight. Questions>>>
I'm thinking of heading to E-town tonight to make a couple of passes.
Being that I haven't run my truck yet, I have a couple of questions.
People with no bed covers, do you run with your tailgate open or closed?
People running stock F1s, do you monkey with the tire pressure? In my SS, I would pump the fronts up to 40 psi and deflate the rears down to about 24 psi. Also, do you do a quick burnout? I know to avoid the box.
If I do decide to go, hope to see some of you there.
Thanks.
Dan
Thanks.
Dan
im no expert ,but id take the tailgate off,
keeping it up has gotta hurt,and i dont know
if track will let u leave it down just in case
it falls off.as far as tire pressure i thought
i read 27 in rear not sure about the front.
someone correct me if im wrong.
I'm thinking about going.
If you take the tailgate of it will save weight.
Lower your tire pressure to b/n 26-28lbs, test to see what works for you and what your comfortable with. I've read of people going lower.
Quick burnout, do what I do, light em up til you see some smoke then stop. It will heat them up a little and clear them of most debri.
