Anyone remove one rear leaf spring?
Old Jul 11, 2002 | 11:22 AM
TXSVTLIGHTNING's Avatar
Over heard someone saying they had removed a leaf on a different make truck to lower it an additonal inch or so. This is kinda what I'm looking for since the 2" shackles didn't go enough for me, and I'm not in a position to purchase hangers at this time.
If anyone has done this, which one cam out, results, tips?? thanks
Old Jul 11, 2002 | 01:04 PM
Spike Engineering's Avatar
Re: Anyone remove one rear leaf spring?
Originally posted by TXSVTLIGHTNING
Over heard someone saying they had removed a leaf on a different make truck to lower it an additonal inch or so...
It was probably done by a GM "enthusiast." They aren't too bright.
If a Ford guy did it, they'd probably remove two leafs - one on each side.
Old Jul 11, 2002 | 01:48 PM
1BADTK's Avatar
I know someone that did that, one each side. Then broke two driveshafts, then added traction bars, and I think put the springs back.
Old Jul 11, 2002 | 05:45 PM
Nasty Wendy's Avatar
Smile Re: Re: Anyone remove one rear leaf spring?
Yea but then it would be lowered like 2". That may be to much.
HEY I'm a GM well a GN person, I resemble that remark.
Old Jul 11, 2002 | 06:12 PM
Figured most would understand, but for those that don't, yes remove one leaf out of "each" side. Thats what I asking about.
Old Jul 11, 2002 | 06:14 PM
Nasty Chick:
I'm glad you understood my sarcasm!
Spike
Old Jul 11, 2002 | 07:37 PM
SouthernStar's Avatar
Cool
You could remove the bottom spring. which is sometimes referred to as the load spring to get additional drop. It will also decrease your load and tow capacity however. You can try it and see if you like it or not just be sure you realign the rear axle and get every thing torqued back to specs. You can always put it back if you don't like it.
