Look what I found under my hood! WTF?
Old Jul 8, 2002 | 09:44 AM
Skank Dog's Avatar
Unhappy Look what I found under my hood! WTF?
I was determined to find the engine miss Ive had since they replaced my pasanger side head. While looking around I found this part lying on the drivers side A-arm. Any body know what its suspose to plug into? What the !@#$ is it?
Old Jul 8, 2002 | 09:55 AM
kidtriton's Avatar
Well, just offhand,, its either a low washer fluid level sensor, a brake fluid level sensor, hmm, with 3 wires cant be a hood light switch, anyway, whats hangin out is a magnetic reed switch, only used in mercury/tilt switches , or floating magnet/low fluid level switches. They probably just broke it off accidentally moving around the heavy head, and then replaced it.
Old Jul 8, 2002 | 10:02 AM
Skank Dog's Avatar
jefflaws- Thanks for the info. Ill go check all the fluid switches and see if thats it. Thanks again!
Old Jul 8, 2002 | 10:05 AM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
Compare to the headlight bulb connector.
Old Jul 8, 2002 | 10:06 AM
kidtriton's Avatar
nah, thats definately a reed switch, not a filament
Old Jul 8, 2002 | 10:11 AM
kidtriton's Avatar
I hobbled (just had hernia surgery last week) out to my truck and looked, its the brake fluid level switch. I think only the expidition washer tank has the fluid switch like that. Im sure its been replaced for you if it was unplugged, they knew they broke it, heck, it might not even be from your truck. Sometimes stuff gets tossed across the shop by disgruntled mechanics, lol.
Old Jul 8, 2002 | 10:21 AM
roger's Avatar
Re: Look what I found under my hood! WTF?
It might be something plant personnel had cobbled up to do some field checks to verify an in-plant repair, etc. If so, the poor guy who dropped it probably cussed a blue-streak when he realized it was gone...
Old Jul 8, 2002 | 10:28 AM
Db682's Avatar
Whatever it is, Its ugly as S#!t. Id play disgrunteled Post Man at your Mechanics Shop if I was you. They tried to screw you and they did a Half as s job at it.
Old Jul 8, 2002 | 10:29 AM
Db682's Avatar
Is that Scotch Tape around the connectors?
Old Jul 8, 2002 | 10:46 AM
BfB's Avatar
BfB
Banned For Rules Violations
How bad is your engine miss? Most likely you have a bad coil pack somewhere. Does your dealer know of the miss?
Old Jul 8, 2002 | 10:55 AM
StruckBy99's Avatar
That looks like an oxygen sensor plug.
If that wasn't plugged in you'd definately have a miss and a SES light.
Check the back of the passenger side head. The plug is actually clipped to the back of the head. Its between the head and the firewall. Its easier to get to if you jack the passenger side of the truck up, then you can reach it through the wheel well.
When they replaced the head they could have easily forgot to unplug the O2 sensor and tore it out when they lifted the head off.
Hope this helps.
By the way, when are you sending me that r/c body to paint for you???
Jason
Old Jul 8, 2002 | 11:05 AM
todd abbott's Avatar
Question whas that
Guys heres a guess, it looks like someone made a test light out of a factory connector, I agree it looks like a light filament stuck into a factory connector, most likely fashioned buy one of the local mechanics to check for power. Todd
Old Jul 8, 2002 | 11:35 AM
DEIMATT's Avatar
Its the 7th fetzer valve..
He he just a little humor..
Old Jul 8, 2002 | 11:53 AM
kidtriton's Avatar
Re: whas that
Did yall not read that i told him what it was? Its not a filament, its a reed switch, its not a O2 plug, they have never had one look like that, it IS the connector that goes to the master cylinder low fluid switch that has a magnetic float in the reservior and a reed swith in the sensor.
Old Jul 8, 2002 | 12:30 PM
soap's Avatar
Re: Re: whas that
Easy tiger
--Joe
