Just installed Lotek "Redesigned" 2 gauge pillar
Old Jul 6, 2002 | 12:44 AM
One Bad L's Avatar
Just got done installing loteks redesigned 2 gauge pillar. its the new one that rkkustoms sells that is held by 2 screws. Install was VERY simple and straight forward. It fits great and is held on very secure unlike the old ones ive heard about. Simply test fit and mark the 2 holes, drill into the metal pillar and then mount the pillar and screw it down. screws are covered by grey colored caps which you dont even notice. i put in autometer phantom boost and air fuel gauges. Found the 7/64th rubber tee fitting at autozone, pulled the stock hard plastic lines off the stock rubber fittings and connected them to the new tee and then put the clear boost line in the other side. Simple. Airfuel was also very easy with only power ground and the o2 wire which i ran through the tranny linkage rubber gromet in the firewall so i didnt have to drill a hole and what'ya know, the o2 wire is right there. its the black one on the plug. just tap into that one. Simple again! then just clean any thing up that hangs or is in the way and wam your done. A tip, the black hard plastic stock boost lines are tough to slide in the new tee, if you just dab your finger in some dish washing soap and rub it on the tips(just lightly coated), it slides right on....Anyways, they work great and took me total of maybe an hour and half and im VERY **** about the way i install my mods, so could be done quicker. BTW, im very happy with RKkustoms. I got my gauge pod 4 days after i ordered, id highly recomend them.
Old Jul 6, 2002 | 01:18 AM
mecca's Avatar
Thats good to hear. Im gonna be ordering a lo-tek pod pretty soon, and its makes me happy that ill be ordering something that'll fit.
-Mike
Old Jul 6, 2002 | 01:56 AM
JagcLightning's Avatar
Great, I think I too will give them a try. Where is the best place to get the autometer guages. I think I will try to get the Lunar series. Thanks, Jeff
Old Jul 6, 2002 | 10:20 AM
Fast Gator's Avatar
Hope you got a lot of patience
One Bad L.....
No Pics?
Old Jul 6, 2002 | 10:24 AM
One Bad L's Avatar
sorry, no pics, i need to get my digi camera to work. ive had my L 2 months and have now the lotek pod and gauges, anderson ford motorsports power pipe and filter, jdm silver bullet exhaust, billet grills, lighted rear ford logo, belltech 3/4 drop and black powder coated stock wheels with a polished lip. I would like to get some pictures up, ill see if i can do that today.
