Fresh Air Induction
Old Jul 5, 2002 | 09:33 PM
2002whitelight's Avatar
Question Fresh Air Induction
Does anyone know of a website that sells fresh air induction kits(the ones that mount under the fender well).
thanks
Old Jul 5, 2002 | 09:40 PM
LightningTuner's Avatar
Here ya go..
http://powersurgeperformance.net/Sho...pexd.asp?id=38
Old Jul 5, 2002 | 09:47 PM
Hey thanks Sal, but it says that you have to buy the power stack filter, is there anyway that induction system will work with the stock air box?
Old Jul 5, 2002 | 09:55 PM
Our setup it a complete aftermarket replacement. The stock air box is replaced by our FASTair box, which uses a 12" powerstack filter. That filter has over 3 times the surface area of the stock or K&N panel filter. I designed the FASTair system by looking at all the available induction systems, modified stock and aftermarket, and removed all the flaws from each for the ultimate air intake setup.
If you are just looking to hook a duct system to your stock airbox, you'll have to build that yourself, but I'm sure many here who've done it an steer you in the right direction.
Old Jul 6, 2002 | 11:30 AM
LIGHTNINROD's Avatar
Smile
Don't waste your money(like I did ) and go with Sal's kit. The s/c scream at WOT will send chills up your backside ......children and women(most) will run away and ricers will break out in tears.
Dan
Old Jul 6, 2002 | 01:47 PM
litnfast's Avatar
So true And if you ever pass a panel truck in full boost you will never forget the sound of the Eaton bouncin back at ya
